Teac A-H500 Amplifier
Problems with Teac A-H500 Amplifier?
Troubleshooting and Support
Solved Problems for Teac A-H500 Amplifier RSS Feed Post a New Problem
Balance problem
Hi guys, I have a problem with the balance on my rear speakers with 5.1. Actually, I'm not even supposed to change the...
1 Solution
TEAC A-h500 integrated stereo amplifier
No sound from the amp - the power standby indicator is blinking. I have unplugged all wires from the back, turned off...
1 Solution
Peavey keyboard amp--Hum takes over all...
I have an ancient Peavey KB100 (a solid-state, 75watt w/1-15" + piezo amp) which I've used for years (typical...
1 Solution
amp blows fuses
Amp blows fuses Checked out OK: output transistors, power supply.
1 Solution
no sound from amplifier
i have no sound fro amp amp powers up normaly i have changed input source and there is nil change
1 Solution
amp
i have a kam kxr150 amp but only one of the channels is working properly (channel a)channel B only has very slight sound...
1 Solution
right channel
My right channel does not work all the time. Initally it will work, but within 10 minutes it goes out. I know it's a 20...
1 Solution
Unsolved Support Problems
Unsolved Problems for Teac A-H500 Amplifier RSS Feed Post a New Problem
Loss of audio output right channel
As described above, I suspect the audio amp has blown. The output has not gone completely, but is greatly reduced. I...
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Remote ControlWith Remote Control
BridgeableNot Bridgeable
Performance
RMS Power at 4 Ohms80 Watts
Signal to Noise Ratio95 dB
Frequency Response5 Hz - 80000 Hz
RMS Power at 8 Ohms50 Watts
THD (Total Harmonic Distortion).03 %
Dimensions
Depth13.13 in.
Height5.25 in.
Width11.5 in.
Weight15 lb.
Teac Contact Information
Main support number-323-726-0303 ext. 617
Sponsored Links
Loading problems.
Top Experts
Ask Me
jfpogie Wiz
1 solutions
Ask Me
Enquiry Wiz
1 solutions
Ask Me
BIG RED 3 Wiz
2 solutions
Repair Service
Find Amplifier and Pre. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
