20 Most Recent Teac DC-D2831 CD Shelf System Questions & Answers
What is the purpose of the Standby button? Mine is on & I can't get it off & nothing works now.
Teac DC-D2831 CD... | Answered on Dec 29, 2018
turn the power off hold down the cd open close button switch power on if that doesn't work its busted
Teac DC-D2831 CD... | Answered on May 02, 2015
The transformer that i had. PN: E190246 Mfr: HF-4822L2TN (single in/output) (ie... two wires in and two wires out)
(Hang Fung Eletronic Ltd.) has a 42.2 vpk >15watts
(power supply for an Emerson 4 in one Entertainment system
(record, CD, cassett, radio)
Emerson Model: NR305TT 19watt
Found info here http://www.olilio.com/file/detail/FQGS2.E190246.html
I hope this helps somebody..
wildhoss109
Teac DC-D2831 CD... | Answered on Feb 15, 2013
try different cd's my has the same problems. maybe due to early era of cd player. some cd's work ok. use as an amp with outboard cd player. good luck
Teac DC-D2831 CD... | Answered on Nov 12, 2010
You cannot find manuals outside.For replacement parts and manuals, contact parts@teac.com.
They will provide you the manual
thank you
Teac DC-D2831 CD... | Answered on Oct 19, 2010
run wire up the wall,and make a big T,with it,also switch to MONO,that will help
Teac DC-D2831 CD... | Answered on Jul 01, 2010
I was having the same problem, I read my users manual and found that there is a time button on the front of the unit itself. My husband must have pressed ithe last time he used it. Works fine now.
Teac DC-D2831 CD... | Answered on Apr 29, 2010
Unfortunately this is not available for download on the web. You can however contact Teac directly.
Technical Support:
voice: (323) 726-0303
e-mail: custser@teac.com
Parts Department:
voice: (323) 727-4840
fax: (323) 727-7632
e-mail: parts@teac.com
Hope this helps.
Thank you,
lee
Teac DC-D2831 CD... | Answered on Nov 13, 2009
try using the reset button on the back of the set
Teac DC-D2831 CD... | Answered on Jun 14, 2009
My DC-2831 started doing the same thing -- and continued, despite repeated cleaning with a CD-player cleaning disc. Oddly, older CDs would play OK, but brand new ones -- commercial CDs, not homemade -- would promptly begin skipping or lock out altogether. Solution?
Unplug the system, lock the turntable stylus arm into place with the attached C-clamp, then carefully unscrew the back and side panels. Once the innards are exposed, gently lift out the CD-player and visually inspect it for hidden dust, pet dander, even fur can get inside there and gum up the works, and that's something NO CD-cleaning kit can ever reach.
Once you've inspected and cleaned the CD-player of all visible dust and dirt, carefully replace the player, make sure it's seated properly within the shell, then reattach the side and back panels in the exact reverse order as you removed them. THIS IS CRUCIAL: if you don't put the stereo back together in the exact reverse of how you took it apart, you'll have components off-kilter, screws that won't go back in (and leftover screws are a sure sign you're screwed it up!) and your CD-player will be even more temperamental than ever. Word to the wise.
If all this sounds too scary, then you'll have to either live with the crappy CD-playing performance, or get a new system. You can't replace the CD-player unless you buy an entire new system. WARNING: these all-in-one turntable systems are VERY RARE anymore, so don't get mad and kick your TEAC or toss it out or give it away on a whim. You'll play hell trying to find a replacement.
Hope this helps!
Teac DC-D2831 CD... | Answered on May 26, 2009
If using computer generated dics , disc usally bad burn progam , bad disk, burn speed to fast. Check out NERO burn. OR dirty eye, clean, laser eye with disc clean disc
Teac DC-D2831 CD... | Answered on Dec 11, 2008
Teac DC-D2831 CD Shelf System Logo
35 questions posted
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Teac Audio Players & Recorders
Most Popular Question
e190246 transformer power
  • Audio Players & Recorders
