20 Most Recent Thomson Lyra PDP2860 Digital Media Player Questions & Answers
Have you tried replacing the batteries?
Thomson Lyra... | Answered on Aug 07, 2016
Are the battery's inserted correct way round?
Thomson Lyra... | Answered on Oct 16, 2015
Download the nokia multimedia player....You can also go to filehippo.com and get vlc media player......
Thomson Lyra... | Answered on May 27, 2013
update system file
Thomson Lyra... | Answered on Apr 15, 2011
I formated my lyra pdp2860 and it lost the file system so i need to download the right free file system.
Thomson Lyra... | Answered on Oct 02, 2010
copy your file and format the unit and try again to see if it works. I hope this solution has been helpful.
Thomson Lyra... | Answered on Sep 24, 2010
RCA audio/video jukebox is refuse to turn of and on,it always wrte USB safe mode, later it will write don't remove the cable it's transfering data.or unpluge and reset. what will i do to off it.
Thomson Lyra... | Answered on Jun 09, 2010
Daniel is a little mistaken with his solution. The resolution of the video is much higher than the little video screen. Stuttering play back has nothing to do with resolution but FPS or Frames Per Second.
Since the video on the little screen is smooth the video should be smooth on your computer as well, just blurry if the resolution is low. However, I am having the same problem with mine and the picture is sharp on my 1080p laptop screen but only appears to stutter instead of playing smoothly.
The camera has dedicated hardware playing it back. This is also the same hardware that is encoding it while recording. My guess would be that the hardware encoding is using a faulty codec that is not playing back well.
Thomson Lyra... | Answered on Feb 26, 2010
I have had that problem a few times, it started after i did a firmware update, so i just undid all the screws holding the back on,(including the 2 under the cf card slot's cover) and unplugged the battery for 10 seconds and plugged it back in and it worked fine.
Thomson Lyra... | Answered on Jan 21, 2010
You can buy a non-working RD2780 media player in Ebay and use the needed parts.
There is not place to buy such buttons alone.
Best regards,
Thomson Lyra... | Answered on Jul 22, 2009
The best way would be to use the software that comes with the Lyra but if you dont have/use it then you simply drag and drop the files as you do with the films.
The difference being that you must manually 'Profile Contents' which is in the 'Audio' menu, if you use the drag and drop method whereas the software does this automatically.
Your files will magically appear when you have done this.
Thomson Lyra... | Answered on Jun 21, 2009
bateri life
chanche the bateri
Thomson Lyra... | Answered on Apr 20, 2009
download here
http://en-drivers.com/187/213/
Thomson Lyra... | Answered on Mar 01, 2009
Try a format, Over a period of time your info can get corrupt from transering music back and forth. To format plug it in to usb. Go to my computer It shows up as a removably disc, usually drive f: Right click on drive f: (or the approriate drive) and click format. Let me know what happens, you will have reload the player, also try bypassing the software you are using to tranfer, by opening up drive f: and clicking and dragging your music into it , or you can copy and paste it into drive f: L8R
Thomson Lyra... | Answered on Dec 28, 2008
I use a converter and convert the file into DivX format and that works fine on the Lyra
Thomson Lyra... | Answered on Oct 20, 2008
on ebay
Thomson Lyra... | Answered on Jul 11, 2008
go to this page, http://rcaaudiovideo.com/en-US/RD2780_Upgrade and follow the instructions, i had this same problem, and i fixed mine
Thomson Lyra... | Answered on Mar 29, 2008
Thomson Lyra PDP2860 Digital Media Player Logo
40 questions posted
Top Thomson Audio Players & Recorders Experts
Damen Wong
Damen Wong
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Thomson Audio Players & Recorders
Most Popular Question
thomson pdp 2860 20 gb mp3 mp4 player
  • Audio Players & Recorders
