20 Most Recent Brother FAX 8350P Laser Printer Questions & Answers
Machine is saying Printer Jam
Open the front cover and gently pull the paper towards the front of the device. Close the cover and press the "Stop/Exit" button.
If you still receive the message then perform a reset.
You need to keep pressing the DOWN or UP to keys a couple of times until you see 'Maintenance 99' displayed on the display. Hold down the 'Set' button to go to stand by mode. Please note that if you press the exit key only after typing in a single digit the machine goes to maintenance mode in initial stages.
Hope this helps.
Shane
2/8/2011 4:34:01 PM • Brother FAX... • Answered on Feb 08, 2011
Reset drum
I'm not sure about this model, but try this:
1) Open the front cover.
2) While the cover is still open press the "Options" button.
3) Press the up arrow ("+" key).
10/8/2009 10:49:23 AM • Brother FAX... • Answered on Oct 08, 2009
Not sending fax
If Cominication error may be you are using moden in same telephone line so better way to use spliter
4/13/2019 4:58:53 PM • Brother FAX... • Answered on Apr 13, 2019
MFC-8710DW
I am going to assume you are using the Auto Document Feeder for when you are copying and faxing.When you lift the scanner top (As if you are placing a single document on the scanner glass) there is a small strip of glass to the left (normally) of the main scanner glass. This is the ADF scanner location. You will find that there will be two marks on this glass at the points you get lines on copied and faxed documents. Normally this is ballpoint ink that was not completely dried when fed through the ADF or Twink (Whiteout) that was not completely dry when fed through the ADF. Using rubbing alcohol or other cleaning products of similar gender clean this mess off the glass. If it does not come off it could be actual scratches on the glass which can only be fixed by replacing the glass.
9/8/2014 4:20:33 AM • Brother FAX... • Answered on Sep 08, 2014
0answers
Wont copy paper
The Brother Linux scanner driver works only with a superuser by default. To use it with a normal user, you will have to make some settings. Setting for normal users http://welcome.solutions.brother.com...1c.html#u13.04 There is also an installer glitch when installing on 64 bit systems. I don't know if it's been fixed or not. Here is the Brother info You'll need to scroll down a bit to find the appropriate brscan version. I think the 430 uses brscan4 but I'm not certain. Install the scan driver. Copy the following files under /usr/lib64/ to /usr/lib/ For brscan4 Users: /usr/lib64/sane/libsane-brother4.so.1.0.7 /usr/lib64/sane/libsane-brother4.so /usr/lib64/sane/libsane-brother4.so.14/ to /usr/lib/. http://welcome.solutions.brother.com...cn.html#f00106 You'll probably need to restart after applying these fixes. Still having Problem Then follow Us For Brother Printer Support
2/24/2014 8:56:04 PM • Brother FAX... • Answered on Feb 24, 2014
0answers
0answers
Como deshabilito el informe de impresion de brother mfc-j1010dw
Question edited and translated to English. We are a North American website, we only speak English. You can't https://www.google.com/search?q=Brother+MFC-J1010DW+%22disable%22+print+report ..
3/23/2024 1:39:34 AM • Brother Office... • Answered on Mar 23, 2024
Brother MFC-J985DW Colour Inkjet Multifunction Printer. Why doesn't the paper jam message go away?
Question edited for clarity. 985 or 895? Usually because the jam hasn't been cleared or the machine hasn't been reset. Remove the paper tray an open the cartridge bay. Open the rear paper door, check underneath. This machine has a lot of paper scraps in it. :>D
3/17/2024 12:10:58 AM • Brother Office... • Answered on Mar 17, 2024
How Do I Fix Brother Scanner Error Code 2023?
https://help.brother-usa.com/app/answers/detail/a_id/74629/~/error-2023---usb-communication-error "Error 2023 - USB Communication Error" This typically indicates a communication error between the Brother machine and the computer. 1. Turn off the Brother machine, wait 15 seconds and then turn the machine back on. 2. Attempt to scan again. - If you're able to scan, then the issue is resolved. - If you still receive the error, go to step 3. Warranty Calculator to check the status of your machine's warranty. If your machine is out of warranty, we offer a repair option. Please contact Customer Service for warranty or repair options. - If the USB port appears undamaged, go to step 5. step 8. here for instructions. 9. Download and reinstall the Scanner driver, which includes the DSmobileCapture software. Click here for instructions. Don't reinstall using the DVD. Instead download the latest version of the software from http://support.brother.com. 10. Attempt to scan again. - If you're able to scan, then the issue is resolved. - If you still receive the error, then the issue is likely caused by a software conflict. If you have another computer, try installing your machine on that computer and scanning. This will determine if there is a problem with this computer. If after troubleshooting you are still unable to scan, contact your computer manufacturer for additional support.
2/20/2024 2:59:01 AM • Brother Office... • Answered on Feb 20, 2024
What does a poor line condition error mean
These errors are usually related to interference, static, or noise on your phone line. Here are some steps to troubleshoot and resolve the issue: Check for a dial tone: 1. Press the Hook button on your Brother Intellifax 2820 and listen for a dial tone. If there is no dial tone, press Hook again and proceed to step 2. If there is a dial tone, press Hook again and move to step 4. 2. Verify telephone cord/line connection: Ensure that your telephone cord/line is correctly connected to the port labeled LINE on your machine (located on the lower left side). If the cord is already in the LINE port, proceed to step 3. If it's connected to EXT, remove it from there and connect it to the LINE port. Press Hook and check for a dial tone. If still no dial tone, proceed to step 3. If there's a dial tone now, move to step 4. 3. Test with a known working telephone: Disconnect the telephone cord/line from the LINE port on your machine. Connect it to a known working telephone and test for a dial tone. If there's no dial tone, the issue is related to the telephone line or wall jack. Contact your telephone service provider. If there's a dial tone, reconnect the cord/line to the LINE port on your machine. Press Hook and check for a dial tone. If still no dial tone, consider warranty and service options. If there's a dial tone, proceed to step 4. 4. Remove splitters or other devices: Check if you have any splitters, commshare devices, credit card machines, or power strips connected to your machine or the telephone wall jack. If yes, remove them for testing purposes. After removing any devices, continue to step 5. 5. Adjust Compatibility settings: Press Menu/Set. Navigate to Miscellaneous > Compatibility. Choose Basic (for VoIP). Press Menu/Set and then Stop/Exit. 6. Send a fax: Insert the document face down in the Automatic Document Feeder (ADF). Adjust paper guides to fit the width of your document. Enter the fax number using the dial pad. Press Fax Start. Remember that testing the Brother machine on a different, known-working telephone line can help determine if the issue is related to the machine or the telephone line. If the problem persists, consider contacting Brother Customer Service for further assistance. If you feel the need to seek another machine, assess the features you need and your budget. Here are possibilities: here are some reputable brands and their models to consider: Epson WorkForce WF-2750DWF: This all-in-one printer and fax machine offers economical ink usage and a convenient LCD screen. Features: Print, copy, scan, and fax. Scan resolution: 1200 x 2400 dpi. Dimensions: 16.73 x 14.17 x 9.06 inches. Weight: 14.55 lb. It's a budget-friendly choice for home and office use. Brother MFC-L6800DWT: A high-speed monochrome laser fax machine with additional features like printing and scanning. Ideal for small offices. Check out its performance and ease of setup. Canon TR8620: A multifunctional all-in-one printer, copier, and fax machine. Offers versatility and functionality for various tasks. Consider it if you need a reliable fax solution
2/15/2024 2:09:59 AM • Brother Office... • Answered on Feb 15, 2024
Brother HL-L2340DW toner reset counter had brother HL-2040D and was able to reset toner counter
1-877-BROTHER (877-276-8437) M-F, 9:00am to 9:00pm Eastern Time
1/17/2024 5:05:45 AM • Brother Office... • Answered on Jan 17, 2024
2answers
Repair a Brother Printer MFC 235C
Depends what is wrong with it.
1/8/2024 2:00:28 PM • Brother Office... • Answered on Jan 08, 2024
Brother ML 100 typewriter. When I type it does different things like symbol or numbers and barely ever prints a letter and if it does its not the same letter that I pressed.
Question edited for clarity and typo. Contact Brother Support for a warranty claim or the address of a Service Centre. Someone is selling a new one for $600! It is a Daisy Wheel printer, so make sure the wheel is located correctly. https://www.google.com/search?q=Brother+ml+100+typewriter ..
12/20/2023 9:32:46 PM • Brother Office... • Answered on Dec 20, 2023
2answers
Factory reset Brother MFC-7320
1. Open cartridge cover
2. Press the button Clear / Back
3. Press start button
4. Print number 11
5. Close cartridge cover
Now, your printer is returned to the factory settings.
10/12/2023 4:41:30 PM • Brother Office... • Answered on Oct 12, 2023
Brother FAX 8350P Laser Printer Logo
4 questions posted
Norman Weimar
Norman Weimar
k24674
View Most Popular
FAX Brother
  • FAX Brother
Most Popular Question
machine saying printer jam
  • Office Equipment & Supplies
