20 Most Recent
Brother MFC-8820D Laser Flatbel Multi-Function Center (MFC 8820D, MFC8820D) Printer Questions & Answers
How to connect MFC-8820D to a router for wi-fi operation
SETTING UP A SHARED NETWORK PRINTERAny printer that isconnected to a computer and is connected on a LAN can be configured so allother computers on the same network can print to this printer. This means thecomputer with the printer attached to it MUST be booted up at all times whenother computers want to access the printer.You need to install theprinter driver on the computer and configure it as a Shared printer.The other computers on thenetwork need to add this printer to their computer.Follow these steps toset-up a shared network printer :-1. Connect the printer tothe computer and install the printer driver.2. Open Printers and Faxes- right click on this printer and click Sharing - click Sharing tab and click Share this printer, and then if you wish you could change theShare name, then click OK3. Right click on theprinter - click Properties - click Print Test Page to confirm printerinstallation.Follow these steps toconfigure the computers on your network :-1. Open Printers and Faxes- click Add a printer - Next - select a network printer, or a printer attached to another computer - Next.2. Select Browser for aprinter - Next3. Click on and expand theMicrosoft Windows Network down to the computer with the printer - Next4. Select Yes for - Usethis printer as the default printer - Next - Finish5. Right click on theprinter - click Properties - click Print Test Page to confirm printerinstallation.
7/24/2012 7:16:47 AM •
Brother...
Answered
on Jul 24, 2012
Brother MFC 8820D
Error Message
Hi Erika:
A burning smell presents when paper is stuck on the fuser (The hot thing that heats the toner to the paper.) I would take out the drum, and peek in the printer with a flash light and see if you see any paper stuck anywhere it does not belong. Usually, the paper will be burnt "Brownish" in color.
With the drum, there are contacts on them. Make sure they are clean; and do not have toner residue on them. Easy to clean with a pencil eraser. Gently, rub the eraser over the metal contacts to clean off residue. Hope that helps you. If so, please leave me positive feed back.
8/4/2011 3:36:08 AM •
Brother...
Answered
on Aug 04, 2011
Maintenance error 7 on a
Thank you for posting to Fixya.com and it is my pleasure to guide you.
I have scanned through the appropriate sections of the
Brother MFC-8820D User Manual & Brother MFC-8820D SERVICE MANUAL
and find no referance to a "maintenance error 7". Please include any and all messages given on the panel LCD!
Please press the reply button and I will check back tomarrow.
It is always a pleasure to help!
6/15/2011 3:12:52 AM •
Brother...
Answered
on Jun 15, 2011
Brother MFC-8820D Machine Error A
For the error code "7a" to be fixed permanently, you need to ensure that the main PCB is fine and is working in good condition.
If the error code is caused due to malfunctioning of the main motor, then you need to check the whole setup by connecting it with another motor.
In this case, make sure that there is no mechanical load present on the main board.
While fixing this error code, you will notice that the motor runs slowly initially and then picks up the speed later.
http://www.fixya.com/support/t5660619-7a_error
9/22/2010 5:17:25 AM •
Brother...
Answered
on Sep 22, 2010
My machine displays on the LCD: "machine error 68"
First, I would recommend NOT trying to manually install this printer by
using the add printer wizard in windows and selecting the the port and
drivers to use. I would use the install cd to set this all up, it makes
setting up this printer MUCH easier. If you are unable to use the
install cd then get the IP address for the printer from your router
admin page then with the printer "installed" go into the printer
properties, go into the port, add a port, and instead of using a
printer name just type the IP address for the printer in. Also for any
networked printer make sure you don't have a firewall blocking it (this
would include making sure that if the printer requires a port opened in
the router that all requests for that port are routed to the IP address
of the printer).
6/18/2009 2:11:57 PM •
Brother...
Answered
on Jun 18, 2009
Brother MFC scanner bar is stuck
check the continuty in scanner cable to cis unit and check the continuity 2ends off scanner cable.
1.cable problem
2cis problem
Cannot reset toner counter for Brother MFC-9140CDN printer
You can reset the toner cartridges via the printer's menu.
- if an error message appears on the LCD display, press the Cancel (X) button to show the main menu.
- Press the Fax button to make the numeric keypad visible. Then, locate and only locate the Asterisk (Star) button on the numeric keypad. It is important to remember its location as it will not be lit up later when needed.
- Press the Home button to return to the main menu.
- Open the front cover of the printer (to access cartridges).
- With the front cover open, press and hold the unlit Asterisk (Star) button for 5 seconds.
- The reset menu will now appear on the LCD display.
- Scroll through the menu to select a color and yield to reset.
- The LCD will read "Accepted" once the reset is complete.
http://www.zinetic.co.uk/brother_mfc_9140cdn_toner_refill_kit-news.aspx
Scan unable af
The scanner unit is faulty or the flat harness was not fitted properly to the main board.
How do I print envelopes on Brother MFC6490CW
Load the envelopes in like paper, tell the printer the size of these to set the paper size, then whatever you're using to print on the envelopes, set up the page size the same size as the envelopes. You should then be able to print on envelopes
How to remove printer head on brother mfc 495 cw
1. Unscrew these three 12.1mm screws holding the control panel in place.
2. Lift up the front panel from the device.
3. Before removing the unit, apply 2 or 3 pieces of tape to secure the top and bottom of the unit.
Visit my computer
Brother mfc490cw printer show offline and error
Hello there:
for the document you want to print click on print and your printer should show up now just click on the printer and look down where it says use printer offline and click on it again and than it will say use printer online and just print from there ok please dont forget to rate this solution for me
best regards mike
Brother MFC490cw
Right-click on the printer in the folder and uncheck the "Use Printer Offline" option to place your printer online and available.
