20 Most Recent InFocus Proxima UltraLight S520 Multimedia Projector Questions & Answers
You will need a VGA cable that can connect the projector to the laptop. This is usually the same cable that connects a monitor to a desktop computer.
Once you have the two connected, you will have to tell the laptop to send the video signal down the cable. This is normally done by pressing the FN (function) key on the bottom row of the keyboard, and the F8 key on the top. It will normally cycle through the following modes: laptop only (default), external, laptop and external.
Hope this helps and good luck.
InFocus Proxima... | Answered on Sep 05, 2013
you will need to get an RS232 compatable remote and wire it together
usually this will only control power on and off and not much more
this is usually done only in commercial set ups are you using it at home or work?
you would be best off getting a pro to install and load/ write code for you
InFocus Proxima... | Answered on Apr 15, 2011
When the lamps are replaced, you need to ensure you have screwed the lamp assembly into the cavity tightly. The lamp assembly presses against a tiny micro switch - if it is slightly loose, then this might trigger a malfunction when the unit is moved.
Other possibility is, perhaps the micro switch is faulty.
Cheers,
"If this has helped you, please rate this solution"
InFocus Proxima... | Answered on Jan 05, 2010
there is a burn spot on one of the light filters located next to the blue lcd panel. it is caused from excessive heat and dust. unfortunately, you'd need to replace the entire optical engine because infocus does not sell individual optical engine parts.
InFocus Proxima... | Answered on Oct 16, 2009
if the fans run, then ,check the lamp or lamp ballast
turn on the projector ,at the same time ,if you can hear a continuous beep beep sound (the ballast igniting the lamp)
means the lamp may be fault,and other parts is working well
I am an expert of repairing projectors for 19 years.
It is my pleasure to receive the message form you,
WhatsApp ID:+8613178867858
Skype:[email protected]
Wechat ID:+8613178867858
Email:[email protected]
Mobile:+86 13178867858
http://www.lampdeng.com
InFocus Office... | Answered on May 31, 2019
Check the menu selections in the manual.
InFocus Office... | Answered on Jan 18, 2019
Probably damage to the LCD or lens due to an old lamp that produces too much heat. If on the lens, clean it carefully with isopropyl.
InFocus Office... | Answered on Oct 19, 2018
InFocus Proxima UltraLight S520 Multimedia Projector Logo
9 questions posted
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
martin hogg
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • InFocus Office Equipment & Supplies
Most Popular Question
proxima s520 seems work fine in any
  • Office Equipment & Supplies
