20 Most Recent
Brother MFC 8420 All-In-One Laser Printer Questions & Answers
My brother MFC 8429 started
Error 74 is Toner Empty. Your machine sounds like it needs a good cleanout inside:
(USE GLOVES AND A MASK) Take it apart slowly bit by bit, use compressed air liberally, when you've gone as far as you dare then put it back together slowly bit by bit and use the air again anywhere you think you'd missed, then turn on and voila! (fingers crossed for you pal, this can be laborious and annoying, but you'll get there)
MFC 8420 Problem
Hi, .inf are product information files and tells the computer the specific brand/model and drivers needed for your all-in-one and are OS specific. They are normally found inside a folder named DRIVER with other files such as .cab, .dll, .sys, etc.
The installer sometimes compresses all of these files in an .exe, .zip or .rar to reduce file sizes. Double clicking on the download compressed/installer will expand or auto-install.
Your download must match the brand/model of the all-in-one and your operating System, XP, Vista etc.
Your drivers/installers may be found here >
welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc8420_us
Hope this be of some help to you. Pls post again how things turn up or if we can be of further assistance. Cheers.
Brother MFC scanner bar is stuck
check the continuty in scanner cable to cis unit and check the continuity 2ends off scanner cable.
1.cable problem
2cis problem
Cannot reset toner counter for Brother MFC-9140CDN printer
You can reset the toner cartridges via the printer's menu.
- if an error message appears on the LCD display, press the Cancel (X) button to show the main menu.
- Press the Fax button to make the numeric keypad visible. Then, locate and only locate the Asterisk (Star) button on the numeric keypad. It is important to remember its location as it will not be lit up later when needed.
- Press the Home button to return to the main menu.
- Open the front cover of the printer (to access cartridges).
- With the front cover open, press and hold the unlit Asterisk (Star) button for 5 seconds.
- The reset menu will now appear on the LCD display.
- Scroll through the menu to select a color and yield to reset.
- The LCD will read "Accepted" once the reset is complete.
http://www.zinetic.co.uk/brother_mfc_9140cdn_toner_refill_kit-news.aspx
Scan unable af
The scanner unit is faulty or the flat harness was not fitted properly to the main board.
How do I print envelopes on Brother MFC6490CW
Load the envelopes in like paper, tell the printer the size of these to set the paper size, then whatever you're using to print on the envelopes, set up the page size the same size as the envelopes. You should then be able to print on envelopes
How to remove printer head on brother mfc 495 cw
1. Unscrew these three 12.1mm screws holding the control panel in place.
2. Lift up the front panel from the device.
3. Before removing the unit, apply 2 or 3 pieces of tape to secure the top and bottom of the unit.
Visit my computer
Brother mfc490cw printer show offline and error
Hello there:
for the document you want to print click on print and your printer should show up now just click on the printer and look down where it says use printer offline and click on it again and than it will say use printer online and just print from there ok please dont forget to rate this solution for me
best regards mike
Brother MFC490cw
Right-click on the printer in the folder and uncheck the "Use Printer Offline" option to place your printer online and available.
