Brother MFC 4800 All-In-One Laser Printer
Problems with Brother MFC 4800 All-In-One Laser Printer?
Keep your PC up-to-date. Get a Free Scan for Brother's latest driver updates.
Troubleshooting and Support
Solved Problems for Brother MFC 4800 All-In-One Laser Printer RSS Feed Post a New Problem
Cannot reset the change drum soon message...
Have tried leaving cover open and pressing options, but it just tells me to close cover!
1 Solution
change drum soon will not clear after new...
Change drum soon message will not clear after new drum inserted I have a Brother MFC 4800 and I have this same problem...
1 Solution
Changing Drum
My Brother printer MFC-4800 usb-1 asked me CHANGE DRUM SOON although my printer works well. Can I not to change the drum...
1 Solution
poor ink quality
My printer is printing fine but I am getting little dots all over the paper, What do I do to fix this problem?
1 Solution
failure printer
when selecting printer 1610 which is 1 of 3 printers i have installed 1610 responds but will not print untill it has...
1 Solution
Unable to print or copy Brother MFC-440CN
I am unable print, copy from this unit. The message is Unable to print 8F. There is no real error message given. I do...
Post a Solution
I have the pixma ip5300 printer and I need...
I love this printer. It has six ink cartridges. After many printings on printable cds, one finally came out with the...
1 Solution
Unsolved Support Problems
Unsolved Problems for Brother MFC 4800 All-In-One Laser Printer RSS Feed Post a New Problem
print out results all in black
hi guys ... i wish you could help me my fax machine lately were printing a plain paper id loaded all in black.. i mean...
Post a Solution
mfc4800
did you ever solve that printer problem with the light printing from a new toner cartridge?
Post a Solution
Deleting a number
I need to delete several individual numbers that are stored in a group fax
Post a Solution
paper jam????
My machine says there is a paper jam and there is no paper in there and nothing will print. I need help.
Post a Solution
station ID. I cannot set my name on the...
I am getting trouble in setting my name on the station ID section
Post a Solution
how do i scan somthing using a brother MFC...
Please help me to endeavor to scan an item
Post a Solution
white lines when i print from mfc...
Hi! Just wondering if you could help me with this problem - white vertical lines happen every time i print from mfc...
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
PlatformPC, Mac
TypeAll-in-One
Technology (Detailed)Laser
Black Print Speed10 ppm
Output TypeMonochrome Printer
Max Resolution (BW)600 x 600 dpi
Technical Features
Form FactorDesktop
Connectivity TechnologyCable
Language SimulationGDI
Status PanelText Based LCD
First Page Out Time12 Second
Media
Media TypeTransparencies · Plain Paper · Envelopes
Max Media SizeA4 (210 x 297 mm) · Legal (216 x 356 mm, 8.5 x 14")
Total Media Capacity200 Sheets
Media Path TypeStraight
Multifunction Features
Copying Speed (Black)10 ppm
Zoom Range, Enlargement200 %
Zoom Range, Reduction50 %
Scanning Features
Scanner TypePath-Through Scanner
Scanner Resolution200 x 400 dpi
Faxing Features
Modem TypeFax Modem
Fax Speed14.4 Bps
Fax Features SupportedPC Fax · Delayed Faxing · Speed Dial · Scan Into Memory · Auto Fax Reduction · Distinctive Ring
Memory
Installed RAM2 MB
Max Memory2 MB
Processor
ProcessorRISC Microprocessor
Processor Speed100 MHz
System Requirements
Operating SystemMicrosoft Windows 95
Warranty
Warranty1 Year
Dimensions
Depth15.72 in.
Height9.57 in.
Width15.56 in.
Weight16.54 lb.
Brother Contact Information
Main support number800-276-7746
Support FAX1-800-521-2846
Sponsored Links
Loading problems.
Top Experts
Ask Me
jackboy Wiz
15 solutions
Ask Me
aosman Guru
4 solutions
Ask Me
Latoof Guru
2 solutions
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
