20 Most Recent
Oakley Inmate Sunglasses Questions & Answers
Oakley dart replacement lens
Hi
I have seen this many times with this same pair of glasses. The lens is defective however Oakley only has a one year warranty so unless you can provide Proof of purchase there is not much they will to for free. You should be able to obtain an RA# and send your glasses in for lens replacements.
Need a batteryu for my O ROKR Bluetooth sunglasses
Hi I'm not sure if you have found the battery yet..but they are available on eBay. You need to know that this is a on going problem with this product and in most cases won't fix the problem. In most cases its the ribbon inside the left side thats become corroded and has failed. I had 2 pair that did the same thing and Oakley said the same thing ...SORRY WE DON'T REPAIR O ROKRs.TRY TALKING TO MOTOROLA. then motorola said talk to Oakley. It was a classic case of pass the buck.I think this problem led to Oakley discontinuing sales of the O ROKR line of bluetooth Sunglasses. They were just to sensitive to sweat damage as they weren't sealed to well.
Is there anyway to tighten my Oakley hinjinx
I' ve never heard "hinjinx" before and even did not find it in my dictionary, but I suppose you mean the hinges and synthetic temples of the sunglasses. I would advise you to go to an optician who will bend the synthetic temples using hot air, so that they get tighter and hold better without hurting you behind the ears. This service should be provided free of charge.
In case the temples are metal with synthetic tip ends, the optician also can bend them to fit exactly the way you want. ( free of charge )
Oakley screw fell out
Here are a few steps you can take to address this issue:
Tighten Existing Screws: First, try tightening the hinge screws. Use a small, flat-head screwdriver to remove the rubber screw cover located on the hinge area. Then gently tighten the screws that hold the hinge in place. Be careful not to over-tighten them, as this can strip the screws.
Check for Replacement Screws: You can search for replacement screws specifically designed for Oakley Tie Breaker sunglasses. Some online retailers offer Oakley replacement screws that can help fix the problem. Look for screws that match the original ones in terms of size and design.
Sunglass Repair Kits: Consider using a sunglass repair kit. These kits often include various sizes of screws and tools for repairing sunglasses. You might find a suitable replacement screw in one of these kits.
Remember to handle the screws carefully and avoid overtightening. If you're unable to find a replacement screw, reaching out to Oakley customer service.
4/20/2024 10:49:19 PM •
Clothing...
Answered
3 days ago
What do you pack in your purse?
Here are list of things you can carry in your purse:
A makeup bag. I do my makeup on the go a lot, so a makeup bag is necessary for me.
A pair of earrings / jewelry.
Hair ties and bobby pins.
A hair brush.
A notebook / sketchbook.
A pen and a pencil.
Pack of tissues.
4/17/2024 7:09:47 AM •
Clothing...
Answered
on Apr 17, 2024
How to clean white shoes properly?
Cleaning white shoes can help maintain their appearance and keep them looking fresh. Here's a step-by-step guide on how to clean white shoes properly:Materials you'll need:1. Mild soap or detergent2. Soft brush or toothbrush3. White vinegar or baking soda (optional)4. Water5. Clean cloth or sponge6. Old newspapers or paper towels Steps:1. Remove Loose Dirt: Knock your shoes together or use a brush to remove loose dirt and debris. You can also use a soft cloth to wipe away any surface dirt.2. Remove Laces: Take off the shoelaces. You can either clean them separately or replace them if they are too dirty or worn.3. Pre-treat Stains:If there are stubborn stains, pre-treat them with a mixture of water and a small amount of mild soap or detergent. You can also use a paste made from baking soda and water for tougher stains.4. Soak Laces:If you removed the laces, soak them in a mixture of warm water and mild soap. You can also add a bit of baking soda or white vinegar to help with stains. After soaking, scrub them with a brush or toothbrush, rinse, and let them air dry.5. Wash Shoes: Mix warm water with a small amount of mild soap or detergent. Use a soft brush or toothbrush to scrub the shoes gently. Pay extra attention to stained or dirty areas. Be careful not to use a brush with stiff bristles, as it may damage the shoe material.6. Rinse Thoroughly:Wipe off any soap or detergent with a clean, damp cloth or sponge. Make sure to remove all residue.7. Dry Properly:Stuff your shoes with crumpled newspaper or paper towels to help them retain their shape and absorb moisture. Let them air dry in a well-ventilated area. Avoid direct heat sources like radiators or sunlight, as this can cause the shoes to yellow.8. Clean Soles:Clean the soles of your shoes separately. You can use an old toothbrush or a small brush to scrub away dirt and grime. A mixture of water and mild soap or a specialized sole cleaner can be effective.9. Protect and Maintain: Consider applying a stain and water repellent spray to protect your white shoes from future stains. Regularly clean your shoes to prevent dirt buildup.10. Polish (for Leather Shoes):If your white shoes are made of leather, you can use a white shoe polish to restore their shine. Make sure to follow the instructions on the polish container.Remember, prevention is key. Try to avoid wearing your white shoes in muddy or extremely dirty conditions, and clean them regularly to keep them looking their best.
4/17/2024 7:05:52 AM •
Clothing...
Answered
on Apr 17, 2024
How much would getting a wedding dress made cost?
The cost of getting a wedding dress made can vary greatly depending on factors like the design complexity, quality of materials, and the expertise of the designer. On average, it can range from a few hundred to several thousand dollars. It's important to consider your budget and discuss pricing with the designer to find the best option for you. For best designer lehengas, saree and ethnic wear you can check Mirraw Luxe online. Visit now: https://www.mirrawluxe.com/trends/wedding
3/8/2024 1:22:32 PM •
Clothing...
Answered
on Mar 08, 2024
