20 Most Recent
Ray-Ban Ray Ban Aviator Sunglasses Metal Frame And Glass Lenses Unisex Questions & Answers
How do you find out if Rayban Aviator are genuine
These are the markings to check for.
Older Models made by Baush and Loma.
-Ray Ban B&L Made in the USA across the top part of the upper bridge.
-Size Markings on the paddles. (Only if they were not changed out, and are not the wrap around ear frames)
-Ray Ban white logo on the Right eye Lens. (Left if you are looking at the glasses) this should not come off easily like, with a cleaning cloth.
-B&L etched in the lenses, many knockoffs will have it painted.
-B&L engraved in the nose guards
Further information needed
Newer Ray Ban's made by Luxottica
-All newer Ray Ban's sold in the U.S.A will be made in Italy.
-Ray Ban Made in Italy under the top bridge
-Made in Ray Ban made in Italy CE on the inside right leg.
-Correct size and model info on the left inside leg.
-R&B etched in the lenses.
-Ray-Ban painted white on the Right Lens (Again won't come off easily)
Applies to both
-Should not have a mix of the above features....common mistake (Example made in USA across the bridge and made in Italy on the leg.)
-If painted, it should be enamel and should not come off easily.
-Hinges should have a distinct shape, not oval, and should not have any "burn" marks on the metal from being fused.
-The paperwork..sometimes called care book. (not the registration card) should be crisp with a professional work. Common fakes are printed with regular or shiny paper, haphazardly folded, sometimes colors will be bleeding, and or the English is full of typos.
-Mispelled words on the protective case if it has one. This should also match with the glasses. Luxottica with Italy made and Baush and Loma with U.S.A.
-Box is beat up or has Asian characters.
-Hinges should move smoothly but should not be loose. (Older/Used may require tightening.)
-Plastic lenses. An easy way to test this is to direct the car A.C. air at the lenses. Glass lenses will cool rather easily will feel cooler to the touch than plastic.
-Have them checked at a local sunglasses place, UV can be tested too. Many cheap priced sunglasses misrepresent the amount of UV that is blocked. Ray Ban's have a good reputation of Blocking that 99-100%
3025 62 18
www.ray-ban.com/
send then in to get them repaired.
The correct serial number on ray ban
look at the box your Ray-Bans came in. There should be a recycling logo,
as well as a semi-permanent sticker on the box, including the serial
number, manufacturer and distributor details, lens and frame type, and
the model number of your specific style of sunglasses. If this sticker
is missing, the sunglasses in the box are probably not genuine.
Oakley screw fell out
Here are a few steps you can take to address this issue:
Tighten Existing Screws: First, try tightening the hinge screws. Use a small, flat-head screwdriver to remove the rubber screw cover located on the hinge area. Then gently tighten the screws that hold the hinge in place. Be careful not to over-tighten them, as this can strip the screws.
Check for Replacement Screws: You can search for replacement screws specifically designed for Oakley Tie Breaker sunglasses. Some online retailers offer Oakley replacement screws that can help fix the problem. Look for screws that match the original ones in terms of size and design.
Sunglass Repair Kits: Consider using a sunglass repair kit. These kits often include various sizes of screws and tools for repairing sunglasses. You might find a suitable replacement screw in one of these kits.
Remember to handle the screws carefully and avoid overtightening. If you're unable to find a replacement screw, reaching out to Oakley customer service.
4/20/2024 10:49:19 PM •
Clothing...
Answered
3 days ago
What do you pack in your purse?
Here are list of things you can carry in your purse:
A makeup bag. I do my makeup on the go a lot, so a makeup bag is necessary for me.
A pair of earrings / jewelry.
Hair ties and bobby pins.
A hair brush.
A notebook / sketchbook.
A pen and a pencil.
Pack of tissues.
4/17/2024 7:09:47 AM •
Clothing...
Answered
on Apr 17, 2024
How to clean white shoes properly?
Cleaning white shoes can help maintain their appearance and keep them looking fresh. Here's a step-by-step guide on how to clean white shoes properly:Materials you'll need:1. Mild soap or detergent2. Soft brush or toothbrush3. White vinegar or baking soda (optional)4. Water5. Clean cloth or sponge6. Old newspapers or paper towels Steps:1. Remove Loose Dirt: Knock your shoes together or use a brush to remove loose dirt and debris. You can also use a soft cloth to wipe away any surface dirt.2. Remove Laces: Take off the shoelaces. You can either clean them separately or replace them if they are too dirty or worn.3. Pre-treat Stains:If there are stubborn stains, pre-treat them with a mixture of water and a small amount of mild soap or detergent. You can also use a paste made from baking soda and water for tougher stains.4. Soak Laces:If you removed the laces, soak them in a mixture of warm water and mild soap. You can also add a bit of baking soda or white vinegar to help with stains. After soaking, scrub them with a brush or toothbrush, rinse, and let them air dry.5. Wash Shoes: Mix warm water with a small amount of mild soap or detergent. Use a soft brush or toothbrush to scrub the shoes gently. Pay extra attention to stained or dirty areas. Be careful not to use a brush with stiff bristles, as it may damage the shoe material.6. Rinse Thoroughly:Wipe off any soap or detergent with a clean, damp cloth or sponge. Make sure to remove all residue.7. Dry Properly:Stuff your shoes with crumpled newspaper or paper towels to help them retain their shape and absorb moisture. Let them air dry in a well-ventilated area. Avoid direct heat sources like radiators or sunlight, as this can cause the shoes to yellow.8. Clean Soles:Clean the soles of your shoes separately. You can use an old toothbrush or a small brush to scrub away dirt and grime. A mixture of water and mild soap or a specialized sole cleaner can be effective.9. Protect and Maintain: Consider applying a stain and water repellent spray to protect your white shoes from future stains. Regularly clean your shoes to prevent dirt buildup.10. Polish (for Leather Shoes):If your white shoes are made of leather, you can use a white shoe polish to restore their shine. Make sure to follow the instructions on the polish container.Remember, prevention is key. Try to avoid wearing your white shoes in muddy or extremely dirty conditions, and clean them regularly to keep them looking their best.
4/17/2024 7:05:52 AM •
Clothing...
Answered
on Apr 17, 2024
How much would getting a wedding dress made cost?
The cost of getting a wedding dress made can vary greatly depending on factors like the design complexity, quality of materials, and the expertise of the designer. On average, it can range from a few hundred to several thousand dollars. It's important to consider your budget and discuss pricing with the designer to find the best option for you. For best designer lehengas, saree and ethnic wear you can check Mirraw Luxe online. Visit now: https://www.mirrawluxe.com/trends/wedding
3/8/2024 1:22:32 PM •
Clothing...
Answered
on Mar 08, 2024
