My Zenith (Model B25A1OZ; Manufacture Year 2000)alternates from a steady picture to like it has lost...
(More)
My Zenith (Model B25A1OZ; Manufacture Year 2000)alternates from a steady picture to like it has lost its Horozontal Hold, there is a double picture ( one on top of another) how do I fix this? There are no Horozontal/vertical Hold Knobs
My grandma has one of these Tv's. Recently when you selected closed captions it does not work and...
(More)
My grandma has one of these Tv's. Recently when you selected closed captions it does not work and she needs it. Any ideas>?
at initial turn on zenith b25a10z tries to sync with signal, turn off after failure to sync. will...
(More)
at initial turn on zenith b25a10z tries to sync with signal, turn off after failure to sync. will continue to turn off if not sync. 10mins later after repeated turn on the tv stays on and the pic is sync.
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
On Feb 18, US viewers with analog TVs will no longer receive free over-the-air programming. In other words, if you've got an older TV with rabbit ear...
written by Lauren_FixYa
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method...
written by techman
Update
A number of people have commented that after changing the color wheel,
their red and blue colors are reversed. This is a different color...
written by sweet_rascal
7. Locate the color wheel cover. It?s got a small green circuit
board on top of it with a black/blue wires connected to it. Remove that
plug. Also,...
My television is model Samsung HLM4365WX and the color wheel part
number for that is BP96-00250A. This color wheel is used in many, many
Samsung...
I?ve got one of the early models of the Samsung 43′ DLP Television
sets. We?ve been through a lot together, but it?s just a...
Don't put up with your faulty buttons on you Remote Control anymore! If some of the keys on your remote have stopped working or you have to push...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
