20 Most Recent
everbuying GS8000L Full HD 1080P 2.7 Inch File Locking G Sensor Car DVR Recorder Questions & Answers
Records only 7 - 9 second :--(
check the sd card on your pc/laptop make sure its in fat32 format. check record settings, on record setting (4gb and above) set it to intervals of 15min. and save setting. sd cards over 8gb are prone to over heat or not record over as it needs to be able to record over older files. 32gb type you need a high end sd card for them to last the better the quality of sd card the better they last. you can also get a corrupted data file either on the video of the format. either way the ds card will need formatting again. hope this helps.
My doorbell has gone quiet
It may have this silent option in either choice for volume or melody. My doorbell has numbered buttons that need to be pressed together with the button to open the door, in order to access these functions.
Another thought is that a battery needs to be replaced.
How can I reset my floureon h 264?
Press the reset button: Using a small tool like a toothpick or paperclip, press and hold the reset button for a few seconds until the DVR resets. This will restore the DVR to its factory settings, including the default password
