20 Most Recent Zenith P60W26 60 in. HD-Ready Plasma Television Questions & Answers
How to factory rest zenith plasma tv
Hi there, Here give this a try and hope this helps.
  • Press the "Menu" button on your remote control. Use the up and down arrow buttons to highlight the video option. Press the arrow that points to the right to select the video option.
  • Use the up and down arrow to highlight the video reset option. Push the right arrow button on the remote control to select video reset.
  • Press the right arrow button on the remote control to return the video to original values.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_70466cb634a57543
5/3/2016 4:46:57 AM • Zenith P60W26 60... • Answered on May 03, 2016
I have a 60 in plasma zenith tv that has pink and green shadowing on the picture what could cause this?
To many things that can cause it, The plasma tube on that spot can be faulty. The Ver and Hor sync part (resistors etc) can be faulty. Magnetic coils faulty. Only thing you can try yourself is unplug Tv from power socket for at least 12 hours and plug in again, remove any speakers or metal from side of tv. Mag coils initiation might rectify it by itself. If this doesnt work get a TV repair tech
10/26/2015 7:43:49 PM • Zenith P60W26 60... • Answered on Oct 26, 2015
2answers
Vertical line in centre of my zenith plasma p60w26 tv
I also have this problem, but with 2 black vertical lines on the right side of screen half way through. Lines disappear from time to time but reappear. Is there anything I can do to get rid of them. Help me out please
.... Thank You.
7/14/2015 2:55:41 AM • Zenith P60W26 60... • Answered on Jul 14, 2015
I have a Zenith P60W26.
Hi Jim,
This is very common faults in plasma tv. Bad news because this kind of symptoms has a lot of parts that are going to consider which was gone to malfunction. The boards most likely to fail are the control board, sustain boards, and the power supply board. They are chain for processing the image and feed to the plasma panel. First the unit must isolate from loose connections and bad solder joints because it will produce same symptoms. All the cable connectors must be pull-out and then re-insert and ensure the connections. Power supply board is prone from bad solder joints (cracked/dried/cold solder) because this is the warmest/hard working among the boards. This is hard to spot, I would advice you to work in the brightest area or used table/portable lamp and magnifying glass and re-solder it on the board.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for a qualified tv technician or send it to reputable repair shop.
Also, check if your unit is still under warranty/extended warranty period, avail it because the manufacturer will fix it for free. Don't attempt to open the back cover(it will void the warranty).
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
5/21/2011 2:22:57 PM • Zenith P60W26 60... • Answered on May 21, 2011
Hdmi port not working for ps3
believe it or not it might be your tv. mine did the exact same thing and i thought it was my ps3 but who wlda guessed its the tv lol. soo heres what you do. leave ur ps3 plugged in to your tv through hdmi, then all you do is unplug your tv from the wall, and wait for about 20 mins then volia!!!!! hmdi at its best. i do not know how it works but it does and i hav not had a problem since.
9/15/2010 1:06:23 PM • Zenith P60W26 60... • Answered on Sep 15, 2010
4answers
Zentih P60w26 plasma
this
9/4/2010 7:12:10 PM • Zenith P60W26 60... • Answered on Sep 04, 2010
Zenith P60W26P beeps and won't turn on until next day.
I am having the same problem, beeping and will not come on until the next day....did you find a solution?
6/3/2010 5:28:02 PM • Zenith P60W26 60... • Answered on Jun 03, 2010
2answers
Request for solution to repair two 60"Zenith HDTV's PN- P60W26P
turns on but no display the model # p60w26 same problem
3/12/2009 6:40:26 PM • Zenith P60W26 60... • Answered on Mar 12, 2009
PLEASE, PLEASE HELP IF YOU
Whats the model number of your Zenith and I will try to locate a owners manual for you.
1/4/2024 2:58:37 AM • Zenith Televison... • Answered on Jan 04, 2024
My zenith CD/DVD duplicator LCD light on but no ready
If the LCD light on your Zenith CD/DVD duplicator is on but it is not showing as "ready," it is possible that there is an issue with the duplicator's internal components or settings. Here are a few troubleshooting steps you can take to try and resolve the issue: Check the disc trays: Make sure that all of the disc trays are closed properly and that there are no discs stuck inside the duplicator. If a tray is open or a disc is stuck, the duplicator will not be able to operate properly. Check the power source: Make sure that the duplicator is plugged into a working power source and that the power cable is securely connected to the duplicator. If the power source is not providing enough power, the duplicator may not be able to operate. Check the settings: Check the duplicator's settings to ensure that it is set up correctly for the type of disc you are trying to duplicate. For example, if you are trying to duplicate a DVD, make sure that the duplicator is set to duplicate DVDs and not CDs. Reset the duplicator: Try resetting the duplicator by unplugging it from the power source for a few minutes, then plugging it back in and turning it on. This can sometimes resolve minor issues with the duplicator's internal components. If none of these steps resolve the issue, it is possible that there is a more serious issue with the duplicator's hardware or software. In this case, it may be best to contact Zenith customer support or a professional technician for further assistance.
3/19/2023 2:53:59 PM • Zenith Televison... • Answered on Mar 19, 2023
Zenith VR4206HF VCR Very Slowly Loads/Unloads Tape
eject motor weak or dirty
11/5/2022 4:21:46 AM • Zenith Televison... • Answered on Nov 05, 2022
I have a Zenith zp505 universal remote(silver w/out a code search botton) . I need the manual and codes for 4 digit codes
I have a sony bravia TV(MODEL:KDL50R550A) I dont know How to reprogram my ZP505 ZENITH Universal 5in1 remote control to it.
9/26/2022 5:02:53 PM • Zenith Televison... • Answered on Sep 26, 2022
My Zenith dvd vhs combo model number xbv 443 dvd tray won't open
you might have to initiate the tray opening mechanism and as it's trying pry the tray forward and force it open it might fix it.
9/18/2022 4:34:41 PM • Zenith Televison... • Answered on Sep 18, 2022
Unlock zenith tv from hotel code without remote
The hotel mode is set by the remote control , not the control panel.
8/8/2022 2:43:24 PM • Zenith Televison... • Answered on Aug 08, 2022
Where can I find a manual for my Zenith ZG120M alarm clock
Not available online, but there is a video. https://www.google.com/search?q=Zenith+ZG120M+manual ..
7/22/2022 3:24:38 AM • Zenith Televison... • Answered on Jul 22, 2022
My 50' zenith tv clicks on and then goes right back off after about 2 seconds what's the cause of this?
Without a model there isn't a way to give any helpful information
7/11/2022 11:09:37 PM • Zenith Televison... • Answered on Jul 11, 2022
My 60 inch zenith plasma tv goes off in the middle of watching TV but always came back on but now the screen is black but sound still works
Is the tv blinking a code on the light in the front of the tv. If so go to manualslib.com input the model number and look up the trouble code in the manual for the tv.
5/27/2022 6:29:44 AM • Zenith Televison... • Answered on May 27, 2022
Zenith P60W26 60 in. HD-Ready Plasma Television Logo
16 questions posted
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Zenith Televison & Video
Most Popular Question
60 in plasma zenith tv pink green
  • Televison & Video
