Put it on progressive scan and can't get it back to regularcan'y get anything from dvd player except...
(More)
Put it on progressive scan and can't get it back to regularcan'y get anything from dvd player except blue screen w/progressive scan mode displayed on screen
I've had the XBV343 unit for some time now but have now added a HD TV (Toshiba 42HL167) to the mix...
(More)
I've had the XBV343 unit for some time now but have now added a HD TV (Toshiba 42HL167) to the mix so want to get the progressive scan feature to work and am having problems. On page 19 of the XBV343 manual, there is the note "Progressive Scan is available only when the VIDEO OUTPUT switch on the rear panel is set to COMPONENT". I find no such switch. When I turn Progressive scan on, all I see on the HD TV is a blue screen with "PROGRESSIVE SCAN" across it. Perhaps I have the cables messed up. Can someone guide me in getting this to work? Thanks in advance. Dave
We were hooking up our childs V-Tech game machine and hit a button on the remote and the player (...
(More)
We were hooking up our childs V-Tech game machine and hit a button on the remote and the player ( DVD we have now discovered ) has went into progressive scan mode...it won't come out of it. What next?
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
