can't get it to interface with the tv. power and commends for the dvd work. the unit worked before...
(More)
can't get it to interface with the tv. power and commends for the dvd work. the unit worked before with the tv. is there a channel the tv should be set to. we are in san francisco.
I have a yellow box with a gray triangle in it. Inside the gray triangle is a "!" mark. ...
(More)
I have a yellow box with a gray triangle in it. Inside the gray triangle is a "!" mark. Under the box are the words PSCAN. Can you tell me what that means.
It appears it will play the dvd. No button on the remote will make anything happen except turn the...
(More)
It appears it will play the dvd. No button on the remote will make anything happen except turn the player off or open the drawer.
While watching movies my unit powers off. After starting the unit up it shuts down again. This...
(More)
While watching movies my unit powers off. After starting the unit up it shuts down again. This recently started. I purchased the unit from Circuit City over a year ago.
While playing DVD's the picture starts shaking for a minute or so & certain closer in camera...
(More)
While playing DVD's the picture starts shaking for a minute or so & certain closer in camera angles seem to aggravate the shakiness. It is similar to the motion that used to be alleviated by adjusting the tracking on VCRs.
All of a sudden our DVD's are all playing in Black and White. We haven't changed anything and yet...
(More)
All of a sudden our DVD's are all playing in Black and White. We haven't changed anything and yet the color is gone. Any suggestions on what may have happened? This unit is not even a year old yet. Thanks...
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
