theres this little light that turned on it looks like a lightbulb with littlelines coming off it. i...
(More)
theres this little light that turned on it looks like a lightbulb with littlelines coming off it. i have a zenith 55in lcd hdtv i bought the tv from someone and ive had it for 2 weeks now and the light just started like a few days ago i was wondering if there is a problem with it or not. thanks
We had a quick dimming of the lights during a storm and everything came back up except the...
(More)
We had a quick dimming of the lights during a storm and everything came back up except the projection tv. I do not have any schematics but have found the fuse just inside the cabinet. Just want to remove it and check with my meter but would like to know where i can get some schematics if i need to go further. Thanks in advance Sheryl Brady
The picture fades from light to dark and back again, and the colors go from perfect to ornage-red...
(More)
The picture fades from light to dark and back again, and the colors go from perfect to ornage-red and very dark. It also gets very fuzzy looking. This just started and got worse very quickly. It seems to go back and forth the entire time I have it on. The manual I have gives very little in the way of troubleshooting / part replacement. Any suggestions?
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D...
written by Ecollier2012
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
