the red is not converging. A repairman tried a new convergence unit, but didn't work He thought it...
(More)
the red is not converging. A repairman tried a new convergence unit, but didn't work He thought it was the red gun. Does that sound right?
can you advise where i can purchase a convergence board for a zenith mod IQD61W35 part # 809-10604...
(More)
can you advise where i can purchase a convergence board for a zenith mod IQD61W35 part # 809-10604 thanks---david r
Hi Terryf, I know what the problem is on this set, but I can't find this part. The Power Module...
(More)
Hi Terryf, I know what the problem is on this set, but I can't find this part. The Power Module 809-10358-R has an error amplfier (Sanken SE080N) tha't completely open. I have tried everywhere to locate this simple IC chip. Some places oversea have it, but want me to by 1200 before they put the order in (no thanks). Do you know of any other zenith sets that might have this IC installed? What would be the best place for used and broken zenith boards? Is there a way to bypass this IC if I use a power conditioner at the input? Any help is greatly appreciated. My direct email is dchays@cox.net.
I have a new toshiba hd-dbs HD-A3 player and set it up on this tv and it displays the right side on...
(More)
I have a new toshiba hd-dbs HD-A3 player and set it up on this tv and it displays the right side on the left and vice versa.....help!!!! this tv is supposed to display 1080i pictures.....and my shaw hd box outputs in 1080i also...........
Sir I was wondering if you can tell me how i can center the picture my tv projects and it is really...
(More)
Sir I was wondering if you can tell me how i can center the picture my tv projects and it is really driving me crazy can you please solve my problem please?
VGA input works okay. When you connect the tuner card it pulls the 12V rail down to 7V. Bad tuner...
(More)
VGA input works okay. When you connect the tuner card it pulls the 12V rail down to 7V. Bad tuner card? Cap folding in the supply?Also we don't have the service manual Help
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
I received a full refund for this tv, Monday Oct 6, 2008. Thomson had a courier pick up this tv at my home 2 weeks ago. Just call the numbers I have...
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
