I have a Zenith D56W25 and I just replaced both 392-110 ic's and still have the blue and yellow arc...
(More)
I have a Zenith D56W25 and I just replaced both 392-110 ic's and still have the blue and yellow arc problems. I?ve read that a low watt resistor may be bad. I have one (RK 54) that looks discolored in the middle but is not brittle and doesn?t smell burnt if that means anything. How would I find out what ohm resistance goes with each low watt resistor? This model TV doesn?t have manual alignment it has an auto ''HD Focus''.
I replaced both stk392-150 ics, I still have the same problem. One night the tv worked fine the next...
(More)
I replaced both stk392-150 ics, I still have the same problem. One night the tv worked fine the next day I turned it on and the convergence was all messed up.
Sound is working when tested with alternate speakers but the sound is not coming out of the TV. I...
(More)
Sound is working when tested with alternate speakers but the sound is not coming out of the TV. I also need a manual.
i need to find a power supply, and a part to fix the focus and i also have another problem when you...
(More)
i need to find a power supply, and a part to fix the focus and i also have another problem when you are looking at the back of the tv there is a thing that looks like a light blub was lose and when you try to turn it on there are little sparks coming from it can i get that part where can i find the parts i need
I have a Zenith D56W25 Rear Projection TV and recently, I have began to see slight ghosting around...
(More)
I have a Zenith D56W25 Rear Projection TV and recently, I have began to see slight ghosting around the menu screens of my cable service. This evening, the TV began to go to a black screen with a green glow a couple of time and now every image has severe ghosting. The TV is just over four years old. Any help would be appreciated.
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D...
written by Ecollier2012
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
