20 Most Recent
Timberland Field Boot Scuff Proof InfantToddler Brown Scuff Proof Boys Shoes for Kids Questions & Answers
Scraches in boot leather
Scratches can be filled in with compounds built to do this. Shoe repair shops can take care of this fory ou.
How do you clean Timberland
Timberland boots are made for hiking and working outside in all kinds of weather. Because of this you can expect your boots to get really dirty. They will need to be cleaned on a regular basis in order to get the most use out of them before having to buy a new pair. There are several ways of going about this because your boots can just be a little dirty, or they could have a stain.
Wet a towel with warm water and wipe down the boots with a side swiping motion. This will remove the dirt and leave your boots looking shiny when they dry.
Clean the bottom of your Timberland boots using warm water and a toothbrush. The toothbrush will allow you to get the dirt out of the tread of the boots. Rinse the bottom of the boots with warm water after you have removed the dirt. Allow to air dry.
Wipe the Timberland boots down from head to toe with baby wipes. You will need to use several to get the entire boot clean. Allow the boots to air dry.
Use a Gonzo Wonder Sponge (see Resources) when your Timberland boots have stains. You use a dry sponge and wipe down the area of your boots that need cleaned. This product costs less than $5 and can keep your boots looking like new.
Take the crust off of a piece of bread and let it sit out and become stale. Rub it over your boots where you have dirt and stains. Watch as the stale bread gets rid of the dirt and stains and brings the boots back to new again.
Get the scuff marks off of your Timberland boots with an eraser. This method really works and is free, assuming you have a pencil with an eraser in the house. Just rub the eraser over the scuff mark a few times and it will magically disappear
Chemical smell
This is offgassing. put them in your porch and let them air off. when cntainers are imported, they need to be fumigated. You likely have that coming off
What do you pack in your purse?
Here are list of things you can carry in your purse:
A makeup bag. I do my makeup on the go a lot, so a makeup bag is necessary for me.
A pair of earrings / jewelry.
Hair ties and bobby pins.
A hair brush.
A notebook / sketchbook.
A pen and a pencil.
Pack of tissues.
4/17/2024 7:09:47 AM •
Clothing...
Answered
21 hours ago
How to clean white shoes properly?
Cleaning white shoes can help maintain their appearance and keep them looking fresh. Here's a step-by-step guide on how to clean white shoes properly:Materials you'll need:1. Mild soap or detergent2. Soft brush or toothbrush3. White vinegar or baking soda (optional)4. Water5. Clean cloth or sponge6. Old newspapers or paper towels Steps:1. Remove Loose Dirt: Knock your shoes together or use a brush to remove loose dirt and debris. You can also use a soft cloth to wipe away any surface dirt.2. Remove Laces: Take off the shoelaces. You can either clean them separately or replace them if they are too dirty or worn.3. Pre-treat Stains:If there are stubborn stains, pre-treat them with a mixture of water and a small amount of mild soap or detergent. You can also use a paste made from baking soda and water for tougher stains.4. Soak Laces:If you removed the laces, soak them in a mixture of warm water and mild soap. You can also add a bit of baking soda or white vinegar to help with stains. After soaking, scrub them with a brush or toothbrush, rinse, and let them air dry.5. Wash Shoes: Mix warm water with a small amount of mild soap or detergent. Use a soft brush or toothbrush to scrub the shoes gently. Pay extra attention to stained or dirty areas. Be careful not to use a brush with stiff bristles, as it may damage the shoe material.6. Rinse Thoroughly:Wipe off any soap or detergent with a clean, damp cloth or sponge. Make sure to remove all residue.7. Dry Properly:Stuff your shoes with crumpled newspaper or paper towels to help them retain their shape and absorb moisture. Let them air dry in a well-ventilated area. Avoid direct heat sources like radiators or sunlight, as this can cause the shoes to yellow.8. Clean Soles:Clean the soles of your shoes separately. You can use an old toothbrush or a small brush to scrub away dirt and grime. A mixture of water and mild soap or a specialized sole cleaner can be effective.9. Protect and Maintain: Consider applying a stain and water repellent spray to protect your white shoes from future stains. Regularly clean your shoes to prevent dirt buildup.10. Polish (for Leather Shoes):If your white shoes are made of leather, you can use a white shoe polish to restore their shine. Make sure to follow the instructions on the polish container.Remember, prevention is key. Try to avoid wearing your white shoes in muddy or extremely dirty conditions, and clean them regularly to keep them looking their best.
4/17/2024 7:05:52 AM •
Clothing...
Answered
21 hours ago
How much would getting a wedding dress made cost?
The cost of getting a wedding dress made can vary greatly depending on factors like the design complexity, quality of materials, and the expertise of the designer. On average, it can range from a few hundred to several thousand dollars. It's important to consider your budget and discuss pricing with the designer to find the best option for you. For best designer lehengas, saree and ethnic wear you can check Mirraw Luxe online. Visit now: https://www.mirrawluxe.com/trends/wedding
3/8/2024 1:22:32 PM •
Clothing...
Answered
on Mar 08, 2024
