20 Most Recent
Bose 36037 Remote Control Questions & Answers
I can´t program my Sharp Aquos LC52D64U with my Bose V30
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "
brand name" to your device; to which you want set-up codes; in the "
Search box at the top right of the display window" to get gathered related posts.
I have bose v30, dishnetwork 612 dvr. When
I recommend you switch from using HDMI cables to using component (R/G/B RCA-style) cables. HD picture is superior through component cabling, and solves several HD picture issues.
What is happening is that when video resolution changes (like from regular programming to commercials) the video information is poorly sent down the HDMI line. Component cabling from your DVR will eliminate this problem.
I hope that helps.
How to set clock....
http://www.bose.com/pdf/customer_service/owners/og_wrcd.pdf
Hold down either Time < or Time > or press either button twice in a row...
clock should start flashing
Bose solo won't turn on. Unplug to reset works but takes countless retries. Tries several outlets with same results. One it turns on it works, until turned off or auto off for a few minutes.
I have the Bose Solo 10 and it did the same as yours. I did all of the suggested fixes and nothing worked. I changed out the IR sensor and it worked for a while and it went out again.I'm an electronic engineer so I unplugged it and did the reset and got the acknowledgement tone. That told me the the units power supply and electronics was good because it does a self check when you reset it. I took the IR board and did a bench test on it. The board worked on the bench. When I put it back in I checked the voltage on pin 7 of the IR sensor, no voltage. I checked the voltage on the main PCB and I had 3.2volts. Checked the ribbon connector and the voltage was getting to the connector on the IR board but it had a bad connection from the ribbon to the board. I put a jumper from the ribbon to the IR board and it's been working all day with no problem. I checked and a lot of people are having the same problem the we experienced. Bose should have a recall on the connector on the IR board because you cannot turn this unit on manually. When you have this problem you can't do anything with this unit because it is too big for a paper weight. The next best thing to do is replace the IR board because I could not find the proper connector that's on the IR board.
Bose Acoustimass 10 basic connection issue on board?
If there are just two wires on the transformer secondary, they are interchangeable. Just to make sure, look on the transformer for markings identifying the wires. If the wires are the same color, have the same terminal connectors (probably so; you said the plug goes on ether way), and the same ID marking on the transformer, they definitely are interchangeable. You could check the end of the plug to see which side has the holes for the pins, then match that to the base of the pin connector on the board if it has a base instead of just two bare pins sticking up.
I'm sure somebody's already told you "after the horse is gone" that you should have taken a picture before disassembly, but that doesn't help now. : )
Bose v35 Sound plays but no picture.
If you have already tried using different HDMI cables and testing the system on different TVs with no success, here are some additional troubleshooting steps you can try:
Check the input settings on your TV: Make sure you have selected the correct input on your TV. Sometimes, the input setting may have changed accidentally, or the TV may have multiple HDMI inputs, so it is worth double-checking.
Check the output settings on your Bose V35: Make sure the output settings on your Bose V35 are correct. Go to the "Video" settings on your Bose V35 and make sure the "HDMI Out" is selected as the output option.
Power cycle your equipment: Try turning off your TV, Bose V35, and any other devices connected to the system. Unplug everything from the power source, wait a few minutes, and then plug everything back in and turn it on again.
Reset your Bose V35: If none of the above steps work, you can try resetting your Bose V35 to its default settings. To do this, turn off your Bose V35 and unplug it from the power source. Then, press and hold the "Source" and "Setup" buttons on your Bose V35 remote control for about 10 seconds until you see "Resetting System" on the display.
If you have tried all of these steps and are still not able to get a picture, it may be a hardware issue and you should consider contacting Bose customer support or a professional repair service for further assistance.
Remote control for Bose Wave Radio
Based on the serial number you provided, the manufacture date of your radio is indeed the 263rd day of 2001, which is September 20, 2001.
Regarding the remote control, the AWR-1G4 model does not come with a remote control as it was designed to be a simple, easy-to-use radio without any advanced features like remote control. However, there are aftermarket remote controls available that are compatible with this model.
It is not necessary to find a remote control with a model number ending in 1G4, as the remote control may have a different model number or may be a universal remote control that is compatible with multiple models. You can search for a remote control that is compatible with the AWR-1G4 by looking for one that works with the same brand (in this case, the brand is likely to be "Acoustic Research") and has similar features.
Keep in mind that not all aftermarket remote controls may work perfectly with your radio, so it's best to read reviews and make sure the remote control you choose is well-reviewed and reliable.
Mute not working on sound bar remote
Please double check that you've restarted all devices involved and then repeat this again. Also, please make sure that the volume buttons aren't stuck in the down position. Also, please make sure that soundbar isn't blocking tv sensor.
You might need to re-setup your bose soundbar.
Thank you.
