20 Most Recent Metz 60CT-1 Flash Questions & Answers
USE A REMOTE FLASH TRIGGER I USE IT ON MY 60CT FLASH ON 5D11
Metz 60CT-1... | Answered on Apr 09, 2014
You may download a copy of the manual from here.
Metz 60CT-1... | Answered on Nov 01, 2013
the charger adapter that plugs into the battery pac from the wall has a fuse inside it open it uo and check the fuse has not blown as that's normally the reason i get no light on the pac also using a small enough file clean off all the terminals and check that the spring terminals contacting the circuit board from the plug are not corroded and contacting correctly
Metz 60CT-1... | Answered on Sep 11, 2012
http://www.metz.de/fileadmin/fm-dam/Download/Photo_Electronic/Bedienungsanleitung/mecablitz/mecablitz_48_bis_76/mecablitz_60_CT_1_D_F_NL_GB_I_E.pdf
Metz 60CT-1... | Answered on Dec 16, 2010
Sometimes the long slide switch (pcb switch) gets worn with metal particles rubbed onto tracks from the contacts. The switch then has partial shorts and only works on certain positions. The track looks black when this happens. Clean with alcohol and rub vigorously with toothbrush and swabs.
Metz 60CT-1... | Answered on Jul 23, 2010
Hey, You can engage a mechanical engineer to design a mouting fixture.Depends on how professional you are. If you need a quick " McGiver" fix --- duck tape will do.
G.Evans
Ontario, Canada
Metz 60CT-1... | Answered on Jan 14, 2010
I screwed it to the base so it can't swivel not the greates fix but it will work until someone tells me where to buy used metz parts
Metz 60CT-1... | Answered on Nov 10, 2009
The dial on the top does nothing to the flash. It's just a guide, like a simple ruler.
Example:
You just set your ASA/ISO (Yellow Line) to Orange DIN/ASA Number to match your camera's ASA/ISO.
Then just read those Scale of F Stops to outside to get FT/M (Feet or Meter).
The true meter from flash is on Handle of flash:
Set Orange Horizontal Line to ASA/ISO Number to match camera.
Set Left Slider, push up & down, to the F Stop that you wanted to shoot.
You have 6 Auto Sensor F Stops
1 for M (Motordrive)
1 for W (Winder)
Hope they are helpful on all photographers using Metz 60CT-1 Flash.
Truly,
atdlee@netzero.com
Metz 60CT-1... | Answered on Jul 16, 2009
Metz 60CT-1 Flash Logo
30 questions posted
Top Metz Cameras Experts
Doberman
TimHu
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Metz Camera Expert? Answer questions, earn points and help others
View Most Popular
Metz Cameras
  • Metz Cameras
Most Popular Question
buku manual metz 60 ct1
  • Cameras
