20 Most Recent Lexmark Wheelwriter 5 Series II Typewriter Questions & Answers
Not likely that you need a print hammer. You may need a plastic print solenoid cap. We sell them for 20.00 includes shipping and instructions.
DickyO
Cleveland Business Machines
216-241-0027
Lexmark... | Answered on Apr 10, 2017
The Daisy wheel is the wheel that has all the letters and numbers on it.
Lexmark... | Answered on Oct 02, 2016
remove the ribbon and turn the wheel on the right side of the ribbon in the direction of the arrow
Try code (lang) key either the X or L depending on when it was made
DickyO
Lexmark... | Answered on Sep 30, 2016
everythin is ok,you by a new wheel with letters and that wheel is for european market ,and y -z ar on the other sides
Lexmark... | Answered on Aug 15, 2013
Check the 2 silver rails that the carriage rides on, they need to have a little bit of oil on them. I f they are dry to the touch, they need to be lubricated with a little bit of a light weight oil. This could also be caused by bad keyboard. Do all the keys seem to work? Try turning machine off and move carriage by hand to the left then turn on and see what happens.
Lexmark... | Answered on Nov 28, 2012
You mosr likely have a broken plastic print solenoid cap. We sell them with instructions for 20.00 including shipping.
DickyO
Cleveland Business machines
216-241-0027
Lexmark... | Answered on Dec 14, 2011
The plastic print solinoid cap is probably broken. We sell them with instructions and shipping for 20.00.
DickyO
216-241-0027
Lexmark... | Answered on Apr 04, 2011
You probably have either a gummy print solonoid or the plastic cap on the solonoid olunger is broken these are available for about 15.00 but are a little tricky to install.
DickyO
Lexmark... | Answered on Mar 09, 2011
Check the printwheel to be sure it is properly installed, turn the machine off and try to move the carrier by hand, it should move with a little resistance, if it is hard to move spray some WD40 on the silver shaft that the printer slides on.
DickyO
Lexmark... | Answered on Jan 31, 2011
The carrier belt may be off or broken.
DickyO
Lexmark... | Answered on Oct 18, 2010
All of the LEDs on steady indicates a major electronic failure, likely the `function PCB'. We, as a service facility, cannot obtain schematics of those boards. We send them to a repair facility.
Lexmark... | Answered on Oct 07, 2010
The keyboard is probably going bad. You can try my btip under WW1000 or contact Geo. Beyers Co. @800-392-8085 for a keyboard rebuild.
DickyO
Lexmark... | Answered on Sep 24, 2010
There are a lot of possibilities. Which lights are flashing? In sequence? Beeps? How many?
These all are codes to the problem.
DickyO
Lexmark... | Answered on Sep 15, 2010
Hi:
Make sure the typewriter is not in Lang mode. If the Lang light is lit up then press and hold the code key to the left of the spacebar while pressing the x key. This will cause the Lang light to go out.
Andrew
Lexmark... | Answered on Sep 02, 2010
The platen is easily replaced. We can sell you one for 35.00 plus shipping but we must know the length of the black roll they are not all the same.
DickyO
Lexmark... | Answered on Aug 09, 2010
You are in the LANGUAGE MODE Code "L" or "X" depending on the age will get you back.
DickyO
Lexmark... | Answered on Aug 06, 2010
Do things print and act normally? If so try code "S".
If there are other problems please be clearer.
DickyO
Lexmark... | Answered on Aug 03, 2010
Tab to the R. margin, press mar rel key, space or backspace to desired position, press R. Mar key.
DickyO
Lexmark... | Answered on Jun 24, 2010
Lexmark Wheelwriter 5 Series II Typewriter Logo
27 questions posted
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Lexmark Office Equipment & Supplies
Most Popular Question
none keys
  • Office Equipment & Supplies
