I have a Emerson PDE-2717 car dvd with dual screens. It loads the DVD but does not play it. What...
(More)
I have a Emerson PDE-2717 car dvd with dual screens. It loads the DVD but does not play it. What should I look at?
I have a Durabrand 7" dual screen portable dvd player in our mini-van and we just started...
(More)
I have a Durabrand 7" dual screen portable dvd player in our mini-van and we just started getting the message - "No Disc" when we put in a DVD. Its been working for well over a year and I just started seeing this when I changed a dvd the other day. The dvd doesn't seem to be spinning. All power is on. Confused. Stephen
I had the player on in my car and when I take the key out the player was still going until I opened...
(More)
I had the player on in my car and when I take the key out the player was still going until I opened my door. The player stopped but did not shut off. you could see the screens still on. When I got back to the car the player was off. We turned it on and no screens. All the wiring checked and also I plugged it in in the house. still no screen.
Good afternoon! We purchased a Durabrand DVD Model # PVD 722 in July. Used it maybe 3-4 times in our...
(More)
Good afternoon! We purchased a Durabrand DVD Model # PVD 722 in July. Used it maybe 3-4 times in our vehicle. There is now no connection in the DC IN JACK. are there any suggestions to fix this? Does Durabrand Company even exsist to get support? Not sure if there is any warranty on the product. I appreciate your advice. Thanks Tracy
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
