When I turn the player on I get a blue screen that I can see very well. When I put DVD in the...
(More)
When I turn the player on I get a blue screen that I can see very well. When I put DVD in the picture gets very faint and you can barely see it. The switch on the side is set to TFT on. What do I need to do?
I need a user manual for a durabrand portable dvd player. the model is dur-1700. does...
(More)
I need a user manual for a durabrand portable dvd player. the model is dur-1700. does anyone know where i can get one?
The durabrand dvd portable was fine. Now, i conect and the image and sound are perfect both, then...
(More)
The durabrand dvd portable was fine. Now, i conect and the image and sound are perfect both, then after 2 to 6 minutes the light on the right becomes opaque and one icon in the screen appears, it is likea square with a line from the top right down to the left. Even if is conected to the power supply occurs the same. If the battery is not working suposse to function conected and on the other hand I tested with another ac adaptor and worked during 20 minutes and once again off. I want to buy a new battery and ac adaptor, and also a car adaptor, available in MIami. PLease help me, oh i lost mi manual, so i dont know the meaning of the icon and the change of the light intensity.
my portable dvd player will show up really good when i turn it on but as soon as i put a dvd in it...
(More)
MY PORTABLE DVD PLAYER WILL SHOW UP REALLY GOOD WHEN I TURN IT ON BUT AS SOON AS I PUT A DVD IN IT THE SCREEN GOES BLACK THEN WHEN I TAKE THE DVD PLAYER OUT THE SCREEN POPS BACK UP AND SHOW CLEAR? WHAT IS WRONG...
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
