I have a durabrand pvs1966 dual screen portable dvd player. It works fine except one end of the...
(More)
I have a durabrand pvs1966 dual screen portable dvd player. It works fine except one end of the connector cord that connects the main unit to the secondary unit is missing one small steel prong. When I power the secondary unit up, it flashes briefly, then goes black. I think I need a new connector cord. Do you know where I can find one? Or is there another problem? Thank you.
I have a Durabrand PVS 1970 Portable DVD Player. I am missing one of the cords that goes between the...
(More)
I have a Durabrand PVS 1970 Portable DVD Player. I am missing one of the cords that goes between the player and the screen. The cord I have says it is a AWM E208931 style 20276 30V Tri Wire. Does anyone know where I can find this cord.
When I put a movie in, it takes awhile to load then it reads not a valid disc. Is there any way I...
(More)
When I put a movie in, it takes awhile to load then it reads not a valid disc. Is there any way I can fix this?
where can i get the cord that goes between the dual screens for the durabrand pvs 1966 portable dvd...
(More)
where can i get the cord that goes between the dual screens for the durabrand pvs 1966 portable dvd player
the 2nd screen can still get power from the main dvd player but the main screen is doing absolutely...
(More)
the 2nd screen can still get power from the main dvd player but the main screen is doing absolutely nothing. anybody know how to fix.?
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
