20 Most Recent
Fisher PC-32S90 TV Questions & Answers
Picture goes off
A temporary solution is to unplug the TV for a few minutes, remove static from the glass with your hand. It is important to unplug rather than turn off. If you have a degauss button you can also press that before unplugging. Wait several minutes or an hour. Then plug it back in. If you have Picture in Picture it may be an issue with that and to permanently solve may need a repair person. The unplugging may get you by for a few days at a time. That's at least better than an hour.
Fisher v plow controller, on/off blinking
It sounds like you may be experiencing an issue with your Fisher plow controller. The on/off blinking could indicate a problem with the controller or the plow itself. Here are a few things you can try to troubleshoot the issue:
- Check the wiring of the controller and plow to ensure that all connections are secure.
- Inspect the controller and plow for any visible damage, such as frayed wires or damaged connectors.
- Check the battery in the controller to make sure it is charged and functioning properly.
- If the problem persists, try resetting the controller by removing the battery and unplugging the controller from the vehicle for at least 30 seconds. Then, reattach the battery and plug the controller back in.
If these troubleshooting steps do not resolve the issue, it may be necessary to seek assistance from a professional or contact Fisher for further assistance.
Fisher paykel DEGX2 dryer squeaking
There is a video that may address your issue. Check it first.
This video will look at a DE62T27GW Fisher & Paykel Electric Dryer that has the following problems: Squealing noise, Making loud noise, Squeaking.
No Sound from Fisher Box TV
I think your problem is with the scart socket . It most likely to be a dry joint on the pin where the sound goes in to the tv. you have to take back cover off the tv and turn the chassis over to do the dry joints if you can do it yourself otherwise get an engineer to do it. Good luck.
Recently acquired a Fisher PC203
If I remember correctly, this is an older model set (late 1980, early 1990 I think). Many cable systems of that era didn't offer the large number of channels they do now, and the cable tuning of many sets was very limited. Most cable companies required you to use a converter box to get all the channels. So you probably aren't missing anything, the set just can't do more.
