20 Most Recent ASUS VivoBook S200E-RHI3T73 Laptop Computer With 11.6in. Touch-Screen Display Intel Core i3 Processor Questions & Answers
Asus s200e bios startup
do you mean the windows login password or the drive password? if it is happening before windows boots up, it is easy to fix, just open the laptop and short the internal battery for 5 seconds, that will wipe out all system password, but you have to reconfigure the bios settings, Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
8/14/2014 8:00:48 AM • ASUS VivoBook... • Answered on Aug 14, 2014
How to turn the touchscreen off on an asus s200e
Go to you device manager (right click bottom left corner --> taskmanager)Locate the touch device (probably under Human Interface Devices)Disable the device (right click the device --> disable)Just out of my curiosity, why do you want this?
11/10/2013 2:44:44 PM • ASUS VivoBook... • Answered on Nov 10, 2013
Using ASUS VivoBook Win 11 - want to send 2.5k files to 500 G Rocketfish HDD, but w/out CD read/write capabilities. Cannot send files to memory stick either. What gives?
I've no clue what you want to do, with what. you do no need move ever. copy them ,drag them. if need be say from HDD to thumb drive, we want to delete the source we do so but only rarely , 2.5K means 2500 files or files 2500 bytes long (size) new PC no CD drive sure, they are too big to fit there so are not there. why are you saying CD ? the PC has SSD as most to now where are your source files, not told a CD now MOVE, as the last step of a move is delete and CD are read only device. so that aside where is this source data no told at all if files are on CD we by a CD reader USB external for $15 cured, better is DVD reader and can do DVD-R and CD-R BOTH AT THE LEAST. then copy them anywhere you want NOT MOVE. but COPY a new thumb drive may need top be formatted to NTFS. and make sure it mounts. as seen in DISK manager. sorry all can do is guess what you are attempting nor source told at all. (data) rockfish target not source model not told 500gb 2.5" or 3.5"drive? they all have models and models matter most,. mmm is it old. is it USB drive does the rockfish have files on it , important? if yes +, no format it NTFS. if yes ,yes, the we must repair the rockfish(ask) all target drives of any kind must be good first. and not FULL. and passes smart testes HDD, (ask) the free app recuva can fix bad data on all that. to use a target drive we find it in explorer. device manager and disk manager and must have drive letter assigned. if yes we can open that drive in explorer and say create a text file in notepad, and save it and reopen it and say look MA,. it's not dead. if no data is there now format it NTFS. (best) as NTFS allows data loss corrections later if need be. not told by you at all what a CD has to do with any of this. I can only guess.
8/18/2022 5:41:04 PM • ASUS Audio... • Answered on Aug 18, 2022
ASUS notebook will not turn on
Make sure battery is installed correctly, and ensure the ac is plugged in at the wall and at the center a/c conversion box.
2/12/2015 9:49:09 PM • ASUS Audio... • Answered on Feb 12, 2015
Hi, my son had an asus altec langslide laptop, when he put the power into the powerpoint it sparked, and now wont come on, i have tried a new charger, but nothing i have also changed thr power point j
What happened it that you has static build up in your hand and then when you plugged it in you discharged and fried.the. board...
No fix
12/23/2014 4:14:07 AM • ASUS Audio... • Answered on Dec 23, 2014
Apakabardunia.com
Welcome to FIXYA.
How may I help you?
4/11/2011 8:33:24 AM • ASUS Audio... • Answered on Apr 11, 2011
How do I change to degree mode on my porpo YH-2000
  1. Power Off: Turn off the device.
  2. Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
  3. Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
  4. Power Off Again: Turn off the device once more.
  5. Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
  6. Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
4/20/2024 8:57:52 PM • Audio Players &... • Answered 3 days ago
Panasonic SA-PM250 CD stereo system. Tune dab radio sa pm250?
this model SA rather than SC seems to be a Middle East model. The SC version doesn't have DAB. https://www.google.com/search?q=panasonic+sa-pm250+instruction+manual ..
4/20/2024 5:59:04 PM • Audio Players &... • Answered 3 days ago
Setting time on fmdott085 V398
All questions need clear 'make model (what it is)' first 3 words. https://www.google.com/search?q=fmdott085+V398 ..
4/17/2024 4:54:26 PM • Audio Players &... • Answered on Apr 17, 2024
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS. Question moved from Cars and Trucks category. Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries. How long is the warranty on AfterShokz? While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase. Jan 11, 2019
How To File A Warranty Claim For Your SHOKZ Headphones
https://www.google.com/search?q=Openfit+Shokz+battery+replacement ..
4/16/2024 4:58:24 PM • Audio Players &... • Answered on Apr 16, 2024
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first. But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
4/16/2024 5:57:29 AM • Audio Players &... • Answered on Apr 16, 2024
ASUS VivoBook S200E-RHI3T73 Laptop Computer With 11.6in. Touch-Screen Display Intel Core i3 Processor Logo
6 questions posted
Top ASUS Audio Players & Recorders Experts
Stan Ford
ADMIN Eric
ADMIN Eric
Larry Ng
Larry Ng
Are you an ASUS Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Audio Players & Recorders
Most Popular Question
turn touchscreen off asus s200e
  • Audio Players & Recorders
