20 Most Recent Grundig S350 AM/FM/SW Radio Questions & Answers
Most likely damage to the solid state components, some are protected from this but it all depends.
Grundig S350... | Answered on Jan 11, 2017
You will need to contact Grundig for this, but really doubt they will supply it unless you are a repair shop that that is authorized to repair their equipment.
You can find one on the following site: http://www.etoncorp.com/Parts_and_Accesories
Grundig S350... | Answered on Dec 30, 2016
U can maybe get the manual from the Grundig web site but I do not know about the schematic.
Grundig S350... | Answered on Aug 22, 2016
Hi, you will have to get the unit checked properly as i can take its not working properly .If it still is working properly i would be keeping an eye on it just maybe a problem crops up.
Grundig S350... | Answered on Jan 15, 2016
most likely there's a defective component (like leaky capacitor). it could be 'toast ' if you can't replace said component
Grundig S350... | Answered on Sep 23, 2015
Audio output final is blown. I hope it is not an IC.
Grundig S350... | Answered on Jan 17, 2015
With old radios it worked to connect the antenna to some central radiator or (metallic) water pipe. Some old wire was used to connect it;
Grundig S350... | Answered on Nov 23, 2014
Simple wire can make a great antenna, and it's relatively inexpensive. I've had the best shortwave and AM reception thus far using a long loop (actually a rectangle) of copper wire as an antenna (but folks shouldn't try a loop with some radios designed for use with powered antennas without inserting an appropriate capacitor in series). If you do try wire, you would want to try to make the loop shape as large as possible, and connect the ends of the wire to your radio's antenna connectors.
The Power Supply voltage could be low..If you're using battery, replace them with new ones...otherwise check the power supply voltage as per specification of the model.
Grundig S350... | Answered on Aug 15, 2014
The radio can use D or AA batteries. There is a switch inside the battery compartment that selects the type of battery.
Grundig S350... | Answered on Aug 11, 2014
I cannot tune AM/FM stations because I think Gang Condensers set may have been failed? Looking for solution and replacement parts for the problem.
Grundig S350... | Answered on Mar 27, 2014
Grundig S350 AM/FM/SW Radio Logo
79 questions posted
Top Grundig Audio Players & Recorders Experts
k24674
xxxxxx xxx
Sheldon Dedek
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Grundig Audio Players & Recorders
Most Popular Question
need owners manual wiring diagram
  • Audio Players & Recorders
