20 Most Recent Knowledge Adventure Vivendi Curious George Reading and Phonics Teacher's Edition Questions & Answers
You need to have a video card with TNL support.
Knowledge... | Answered on Apr 09, 2017
if you thanks you click on helpful and also write there .....thanks...
Computers &... | Answered 4 minutes ago
https://www.pdf-unlocker.com/
purchase a PDF unlock programe such as i linked to
Computers &... | Answered 1 hour ago
The question is not clear, where you are trying?
What exact error you are getting?
Please provide at least some brief information.
Computers &... | Answered 2 hours ago
Where?
Please provide brief information atleast aout your issue, what error you are getting. What device you are using.
Computers &... | Answered 3 hours ago
get yourself a VPN app or program. I recomend VPNUNLIMITED go for the lifetime licence...its a great deal. that way Your ISP cant block or see where you go on the internet
https://stacksocial.com/sales/vpn-unlimited-lifetime-subscription
Computers &... | Answered 4 hours ago
Serial Port Signal Names Header Comments Serial1 /TxD1, /RxD1, XCV1+, XCV1- HCS12 Comm Header Standard baud rates up to 115.2 Kbaud. Jumper selectable RS232 or RS485. Jumper selectable termination options. All signals are also available on the Docking Panel. Serial2 /TxD2, /RxD2, XCV2+, XCV2- HCS12 Comm Header Standard baud rates up to 115.2 Kbaud. Jumper selectable RS232 or RS485. Jumper selectable termination options. The RS485 signals are not available on the Docking Panel. IIC SDA, SCL Analog Field Header 2-wire multi-drop bus, up to 100 Kbaud. Each device must have unique numeric address. SPI0 MOSI, MISO, SCK Wildcard Bus Header 3-wire multi-drop bus, up to 10 MBaud if SPI bus master, up to 5 MBaud if SPI slave. Each device must have unique hardware chip select signal. SPI1, SPI2 MOSI1, MISO1, SCK1, /SS1, MOSI2, MISO2, SCK1, /SS2 SPI Header Used for inter-processor (IP) communications on multi-processor systems such as the PDQScreen. Can be used to communicate with other peripheral devices if multi-processing is not required.
RS232 and RS485 communications The PDQ Single Board Computer (SBC) has two asynchronous serial communications ports named Serial1 and Serial2. Each serial port can be configured for the RS232 or RS485 protocol, and runs at standard baud rates up to 115,200 bits per second. The default baud rate after a factory cleanup is 115200 baud. The Serial ports are implemented by the dual on-chip hardware UARTs (Universal Asynchronous Receiver/Transmitters) on the Freescale 9S12(HCS12) microcontroller.
Each UART (sometimes referred to as a "USART") controls the serial-to-parallel and parallel-to-serial conversion and performs all of the timing functions necessary for one asynchronous serial communications link. They translate the bit-by-bit data on the serial cable into bytes of data that can be interpreted by the operating system or by your application program. The communications is asynchronous because no synchronizing clock signal is transmitted along with the data. Rather, the UART deduces the correct time to sample the incoming signal based on the start and stop bits in the signal itself.
The Serial1 and Serial2 ports have identical communications capabilities, although more of the Serial1 signals (both RS232 and RS485) are made available on the Docking Panels headers and connectors. After a factory cleanup, Serial1 is the default serial port for program development and downloading. In a finished instrument, either or both channels can be used to communicate with other serial devices, or with other computers and/or terminals using RS232 or RS485. Having a second serial port is also handy for system debugging. Since both channels can operate simultaneously and independently, serial debugging can be performed while the application program is
sata does not have jumpers for primary or slave
the only jumper is to speed up your harddrive when using ot
Computers &... | Answered 5 hours ago
Knowledge Adventure Vivendi Curious George Reading and Phonics Teacher's Edition Logo
2 questions posted
Top Knowledge Adventure Computers & Internet Experts
 Grubhead
Grubhead
k24674
 Brian Main
Brian Main
Are you a Knowledge Adventure Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Knowledge Adventure Computers & Internet
Most Popular Question
cannot initialize video fixed function
  • Computers & Internet
