20 Most Recent
Fender American Precision Bass Questions & Answers
I have a Fender Precision Bass Guitar serial #503122. I'm curious about its age and value? It is in excellent condition.
this should be a 1960 bass and there was 18,000 of them made so it is not rare but the questions that must be asked to put it in the rare category is the bass 100% original = this means everything /pots /pickups /tuners /frets /finish and then the overall functioning of the parts EX. bent tuner that turns restricted causing tuning problems / pots that cut out / input jack that's screwed up / buzzing or severely worn frets /and or fret board wear /worn finish on the body/neck so you must go down the list of everything to come to the overall condition of your bass then you can grade it by it's condition and then see where the basses category is (PRISTINE) =never used still tags & case (fine) = slightly used tags & case (excellent)= used but no finish chips scratches everything original & working so you get the picture I am curious about this because most players know there basses very well so this tells me that you have acquired this bass recently or that it belonged to a family member? and was passed down to you post back with more info/pictures of the bass I'd like to see it Stephen
Fender serial number look up
The "S" means it was manufactured in the 1970's. The "8" means this was made in 1978.This serial number would suggest this is an 1978 American P Bass. Depending on the condition, you should be expecting to get in between $1200 and $2000. But always remember, a guitar is only worth what people are willing to pay.
Fender serial number look up G14449
something is wrong here the serial number is missing either a # or letter the G denotes a Japanese bass and the year would be 87-88 the prefix GO and 5 #'s wood mean it is a walnut p bass special from 1982 ?
How to operate an acoustic fender electric guitar Fishman tuner
If it's the same as mine, the tuner has a little clothespin clip. You clip that on to your guitar's headstock and turn it around till you can see the screen while picking strings. The tuner picks up vibrations through the headstock and with it's microphone and it tells you what it hears. The little needle tells you the note and if the string you're plucking is below that note, above that note or right on. You have to figure out if you're in the right octave on your own.
12/15/2023 7:48:03 PM •
Fender Music
Answered
on Dec 15, 2023
How can i control 2 different fender hot rod deluxe 3's drive channels with just 1 footswitch? Thank you in advance
You could buy a Lehle switch, or simply use one on each separately. If you are using a multieffect unit you could make a Y cable to take the output to both amps but that will not allow you to select the drive channel - you still need the Fender footswitch for that, one for each amp. Lehle is a German company and they make a lot of different footswitch combinations but you will pay for the convenience.
I recommend the Fender single button footswitch for this use - Type: Footswitch
Number of Footswitch Buttons: 1
Manufacturer Part Number: 0994052000
It's about $35.00 each, compared to the Lehle which starts at $200. Just put the two side by side and make a metal bar to attach to the two switches - then you have a single bar to activate both drive channels at the same time. I recommend using aluminum bar stock with holes drilled into it for the switches, or find a C channel aluminum bar that will put the footswitch buttons in the channel. You can also make it one inch overhang past both switch bodies and then use bolts to keep the bar in place. If I was doing this I would mount the footswitches on a board and secure the bar to be on top of the footswitches, using coil springs to maintain the bar's alignment vertically at the end bolts.
11/22/2022 1:29:51 PM •
Fender Music
Answered
on Nov 22, 2022
Guitar amp input not working
Get inside it and check the connections to the plug especially any shielding / braiding. Resolder the connections.
4/17/2022 3:41:52 PM •
Fender Music
Answered
on Apr 17, 2022
