20 Most Recent KLH DA1302 5-Disc CD Changer Questions & Answers
No. Do you see speaker connections on it?
KLH DA1302... | Answered on Nov 18, 2012
Welcome to Fixya
Sound like there is a problem with the gears inside the unit. One of my fellow expert was able to resolved the issue here in Fixya. Please refer to this link.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
KLH DA1302... | Answered on Dec 18, 2010
Hi: Im Ronald Marts in January 2008 I posted a problem with my KLH DA1302 5-Disc CD Changer,it is still posted on this website on the details of my problem I found that with the top off the door will not open or close, the disc will spin but thats all. After checking all wiring, screws for looseness I gave up and put the top on, being frustrated I foregot to unplug the machine before putting the top on. I put my hand on the top in front of the machine to put in the screws on the back, in the meantime my wife pressed the open- close button and it worked, when I took my hand off it quit working, there is a metalic metal strip on the inside of the top in front that has to make contact to the components inside to solve this problem I put two pieces of wood wrapped up in a wash cloth and wedged them on top of the machine and the cabinet it is kept in one on each side towards the front I know It sounds crazy but it works and my wife is estatic, she likes to listen to her CD,s with her cordless ear phones when she does things around the house. I hope this has helped you all with this problem.
KLH DA1302... | Answered on Aug 21, 2010
Is this a problem? - you're very vague.
Red is right channel out; white is left channel out.
KLH DA1302... | Answered on Nov 10, 2007
you may have an "intelligent" tv that only turns audio on when video is also present. if your tv is older, then go thru the menu options and look for option that turns back panel inputs to "on"...or it may be as simple as finding that option on the remote control.
disconnect offending unit. then play see if same response occurs on the alleged normal unit using the offending cable interchange cables see if you get same result. Means it's bench repair ,internal electronics require specialist equipment to locate the offending item.
KLH Audio... | Answered on Oct 31, 2018
You could check it by having the unit switched on a touching each of the pins of the device with an insulated tool. Making certain you don't short any of the pins together. You should hear a buzz on each channel. If you get nothing on the right then it could well have gone.
However that is a lot of messing about, as the device can be purchased for around £12, it could be easier just to replace it and see if that cures it. After all it is the device that does most of the work, so the chances are it's gone!
KLH Audio... | Answered on Oct 01, 2018
KLH DA1302 5-Disc CD Changer Logo
Popular Tags
13 questions posted
Popular Products
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • KLH Audio Players & Recorders
Most Popular Question
klh da1302 5 disc cd changer door will
  • Audio Players & Recorders
