20 Most Recent Beko 17WLB450S 17 in. LCD TV Questions & Answers
Tip
SERVICE MODE TO BEKO 23WL46G 30WL46G
Service Menu StructureThe service menu has three items: display, calibre and version 2.1 Display Display item has seven options:
a- Panel
Panel option gives information about the current panel resolution. It is a read only option and can not be set.
b- Power on time
Power on time gives information about the last update time of the SW running. It is a read only option and can not be set.
c- Backlight on time
Backlight on time option reserved.
d- Scart prescale
Scart prescale option sets the prescale values for the input sounds entering the scart input of the MSP(Micronas Sound Processor). Changing this value you can adjust the level of the output sound going to loudspeakers for all the sources except the Tuners. The range is between 0 and 100.
e- nicam prescale
Nicam prescale option sets the prescale values for the Nicam standard sounds for tuner inputs. Changing this value you can adjust the level of the output sound going to loudspeakers for Nicam sounds entering the analog sound input of MSP. The range is between 0 and 100.
f- fm/am prescale
fm/am prescale option sets the prescale values for the FM/AM standard sounds for tuner inputs. Changing this value you can adjust the level of the output sound going to loudspeakers for FM/AM sounds entering the analog sound input of MSP.
g- Agc(Automatic Gain Control) adjust
Agc adjust option sets the input voltage going to IF decoder AGC pin. Changing this value you can adjust this voltage for optimum Tuner performance. The range is between 0 and 31.
h- R/G/B Brightness/Contrast:
These are used for color bias adjustment. The range is Between 0 and 255
Calibrate
Calibrate item has nine options:
a- video format
Video format option force the video format to the desired format. Selectable formats are Auto, Pal, NTSC and SECAM.
FOR MORE CHECK THE LINK BELLOW
Electronics Equipment Repair Center
Ajin Gopakumar Google
on Feb 16, 2015 | Beko 17WLB450S 17 in. LCD TV
Main board fault. Shorted component/s on this board. Contact any service technician. This is not a user repairable fault. Gopakumar Gopalan Google
Beko 17WLB450S... | Answered on Mar 05, 2014
if you please visit the link below you can find the user manual for your TV ..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
http://www.beko.co.uk/Manuals.aspx
Beko 17WLB450S... | Answered on Jun 24, 2011
I have the User manual/
instructions in PdF format that you can look in.....
pls send me an e-mail ,I can forward it to you..
Take care and do not forget to rate me too..Thanks
kerguney@gmail.com
Beko 17WLB450S... | Answered on Jun 13, 2011
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Beko 17WLB450S... | Answered on Jan 05, 2011
If the stand-by light doesn't even light up then the power source of your tv is completely fried. The tv is repairable - all you need to do is to replace the power source. But that will cost you around $50 for a second hand source ($100 for a new one) plus the labor of a guy you will have to call to do the job - around $75. I don't think this tv is worth that much money, you can get a new one for a little more.
Beko 17WLB450S... | Answered on Nov 04, 2010
The power supply could be becoming erratic, periodically failing then recovering.
Beko Televison &... | Answered on Mar 05, 2018
not sure on this one but i think you need to go into your tv setting and see what hdmi setting you need to be on to pick up the laptop,where as some tv just picks the laptops up with out going into the setting.
but link i said not sure if this is what you have to do.
Beko Televison &... | Answered on Nov 02, 2017
Beko 17WLB450S 17 in. LCD TV Logo
23 questions posted
Popular Products
Beko 142746 TV
Beko 142746 TV
-17 Questions
Top Beko Televison & Video Experts
Marvin
Marvin
Andy Latty
Andy Latty
Level 1 Expert
Steve Allison
Steve Allison
Are you a Beko Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Beko Televison & Video
Most Popular Question
need instruction book tune in
  • Televison & Video
