20 Most Recent Minolta PageWorks 25 Laser Printer Questions & Answers
Inner fan does not work
What code is the machine giving machines have several fans do you know which one? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/10/2015 1:36:55 AM • Minolta... • Answered on Jan 10, 2015
Minolta EP1050 CS Pro. It is stuck in A3 lengthways mode, I was copying in A4, wanted to go to book mode, pressed button but machine became stuck in A3 lengthways mode instead.
Change it back. Here is your manual. https://www.manualslib.com/manual/1001522/Konica-Minolta-Bizhub-Pro-1050.html?page=110#manual There is also a Service Manual available for it if you ever need it.
MINOLTA EP1050 GENERAL Service Manual download ...
Elektrotanya https://elektrotanya.com > minolta_ep1050_general.pdf Download MINOLTA EP1050 GENERAL service manual & repair info for electronics experts. ... MINOLTA EP-1080 CS-PRO A3-COPIER 1993 SM service manual. MINOLTA EP-1080 ... ..
10/4/2023 4:52:00 PM • Minolta Office... • Answered on Oct 04, 2023
Konica Minolta Bizhub C203 Color, Laser MFP. It jams paper, I have checked it and have even changed the fuser unit, but still the same thing. Please what can I do?
Question edited into written English. Misfeed Error, or Timing Error. You need dealer service. This is a Professional Machine. The fuser only heats the toner to set it on the paper. It is nothing to do with jams.
3/16/2023 2:13:56 AM • Minolta Office... • Answered on Mar 16, 2023
I have a c3513 error code on my kondica minolta bizhub pro 1060L. Does anyone know what this means... thanks Anthony
Yes the Fuser unit that part that is very hot well one of the sensors has detected a very hot temp. get a tech out o look at and reset it Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/17/2023 1:37:14 PM • Minolta Office... • Answered on Feb 17, 2023
Hi i have minolta Dialta 520 Photostate machine
The error code C-1028 on a Minolta Dialta 520 photostat machine typically indicates a problem with the paper feed system. Based on your description, it seems that you have already replaced the PWB-B Board and checked all jacks, but the problem persists. In this case, there could be a few other potential causes of the error.
  • Paper feed motor
  • Main control board
  • Gears or other parts in the paper feed system
  • Paper feed sensor
Regarding the Bet Pin, it could be the name of a specific pin on the PWB-B board or in the paper feed system, but without more information about the specific location or context it is hard to say exactly what it is referring to. It is recommended to consult the service manual of the machine, or contact the manufacturer or a professional technician for further assistance. They will be able to diagnose the issue and provide the necessary steps to fix it.
1/21/2023 10:56:22 AM • Minolta Office... • Answered on Jan 21, 2023
What is the meaning of call for service 001 on Minolta 190f
Something to do with main motor. paper jam. Or bad main motor.
11/6/2022 5:23:20 PM • Minolta Office... • Answered on Nov 06, 2022
Which finisher is compatible with Minolta C451
Konica Minolta FS-517, FS 518 FS 508
10/21/2022 10:19:55 PM • Minolta Office... • Answered on Oct 21, 2022
Minolta di 620. What causes error C-13F0?
Open the front door of the copier, copier must be on. Look to your upper left, you should see a small cover with a screw remove and the cover. Inside you will see a two small buttons, the left one, press it that should reset the copier. Then power off thw machine and wait 10 seconds and power it on. AGAIN if this code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code!!!!
10/21/2022 10:17:54 PM • Minolta Office... • Answered on Oct 21, 2022
We have an older minolta bizhub 250 and the touch screen is working but now where you touch. can this be fixed or do we need to find a replacement part
Sir/Mam, On the right side of the machine just below the scanner section (The part with the big glass) is a cover next to where you connect the Ethernet cable. Remove the cover, with the machine on use a small screw driver and gently depress the small black switch. The machine is going to go thru some screens watch the left side of screen in the middle you will see a "." when that is displayed press 3. If required Enter the 8-digit service code and touch [END]. (Default value: 00000000) Select Touch panel adjustment Touch the four + in the four corners Upper left, Upper Right, lower left, lower right. Power off machine wait 10 seconds power on.
10/21/2022 10:02:10 PM • Minolta Office... • Answered on Oct 21, 2022
Minolta EP 3170 copier will not switch on
Ensure the power plug is properly installed not lose. That is a serious legacy (Super Very Old) machine. Unplug machine and remove rear covers. Look for fuse or circuit breaker. loose connections. if notice nothing plug in and using a volt meter test for voltages on any red wires connection. Black and white wires are 120 VAC be care full green ground
10/21/2022 9:49:34 PM • Minolta Office... • Answered on Oct 21, 2022
Minolta 206 not going to power saving mode
Try Admin Settings select Machine settings.
10/21/2022 9:37:50 PM • Minolta Office... • Answered on Oct 21, 2022
Konika Minolta bizhub 165e Maintenance Call M2 Call Service Machine Trouble Service Code C2558
Replace the drum and developer unit. Ensure that machine has proper toner and toner is getting into the developer unit
10/15/2022 6:03:35 PM • Minolta Office... • Answered on Oct 15, 2022
What does the code c-d201 stand for on a c252 printing bizhub machine
The memory board is bad or not in the correct location. If only one memory stick it should be in the slot marked Bit 0. if two sticks of memory both should be installed. Remove the stick with power off and clean contacts and re insert correctly.
10/15/2022 6:03:34 PM • Minolta Office... • Answered on Oct 15, 2022
The machine not working sowing please wait only
Trennen Sie beim Start externe Laufwerke, Peripherieger?te usw., warten Sie einige Minuten und schalten Sie Ihr System mit Kamagrabest ein. Jetzt fahren Sie Ihren Computer dreimal hintereinander kaum herunter und dann wieder ein. Befolgen Sie diese Schritte Kamagra Bestellen https://kamagrabest.net/, indem Sie zuerst den Computer einschalten und dann direkt den Netzschalter erneut dr?cken, aber diesmal gedr?ckt halten.
9/24/2021 6:46:14 AM • Minolta Office... • Answered on Sep 24, 2021
Hi, can some one help me; i've error code 3b02 displayed in minolta c452
Sir/Mam, Turn off the main power switch, ensure the sub power switch is on. The sub power switch is located on the right side of the control panel. Then holding down the Utility/Counter button turn the main power switch on. Close the front door you must keep the Utility button down. The screen will show TROUBLE RESET touch it sees a "OK" then power off the machine. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back, you need a Fusing unit or a High Current Device for the fusing unit. Which will be expensive!!! Sorry :( DO NOT KEEP TRYING TO RESET THE MACHINE! THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!! A Fire could occur and that would ruin a perfectly good day!!!!
4/11/2021 10:42:47 PM • Minolta Office... • Answered on Apr 11, 2021
Konika minolta c554e error code C-3102. HOW DO YOU FIX THIS.
1 Check the fusing unit for proper installation and correct as necessary.
2 Check the connector between M3-PRCB CN2 for proper connection and correct as necessary.
3 Check the connector of M3 for proper drive coupling and correct as necessary.
4 PS37 I/O check, sensor check.
5 M3 operation check PRCB CN2-9 (REM) PRCB CN2-12 (LOCK) bizhub C554 22-J bizhub C454 21-J.
6. Replace M3.
7. Replace the fusing unit.
8. Replace PRCB.
9/4/2020 10:28:41 AM • Minolta Office... • Answered on Sep 04, 2020
2answers
How to fix Error Code C3901 on a Minolta Bizhub 420 copier
FIRST, if this code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code!!!! AS this is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!! 1. Turn OFF the main power switch. Inside machine, leave sub-power switch on (Right side of control panel) 2. Turn main power switch ON while pressing the Utility/Counter key. 3. Touch [Trouble Reset]. 4. Check to make sure that [OK] is displayed and then it has been reset. 5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
8/23/2020 3:14:47 PM • Minolta Office... • Answered on Aug 23, 2020
Minolta PageWorks 25 Laser Printer Logo
1 questions posted
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Daniel Blask
Daniel Blask
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
PageWorks Minolta
  • PageWorks Minolta
Most Popular Question
inner fan not work
  • Office Equipment & Supplies
