20 Most Recent
06-10 Chevy TrailBlazer LT Bumper Billet Grille Grill Questions & Answers
How to reset automatic sliding door on chevy venture van
The rear side door actuator control modules monitor the power sliding door positions at all times. Whenever the battery positive voltage supply to a rear side door actuator control module has been removed or the on-board diagnostics have been activated the power sliding door system(s) must be re-initialized. Re-initialize the right or left power sliding door systems using the following steps:
- Turn the ON/OFF switch for the power sliding door system to be re-initialized to the OFF position.
- Manually open the power sliding door completely.
- Manually close and latch the power sliding door.
- Turn the power sliding door ON/OFF switch to the ON position.
- Open the power sliding door completely using the B-pillar or overhead console OPEN/CLOSE switch.
- Close the power sliding door completely using the B-pillar or overhead console OPEN/CLOSE switch.
9/9/2022 4:43:40 AM •
Chevrolet...
Answered
on Sep 09, 2022
Check engine light on says p2000 on code reader
The code is: P2000 NOx Trap Efficiency Below Threshold Bank1 and I do not know what that is unless it has something to do with the oxygen supply to the engine. Sorry I am not much help.
10/30/2015 6:24:22 PM •
Chevrolet...
Answered
on Oct 30, 2015
Switch wont turn
it that on the door the heater the radio the steering column or on your Sony Walkman??
3/26/2015 5:11:11 PM •
Chevrolet...
Answered
on Mar 26, 2015
My 66 vett has a replacement vin plate special plate Pennsylvania issued 012874 why would this happen
Pennsylvania is totally messed up, I am sure you have found that out,
you may need to find out where and who put the tag on the vehicle, ie, which notary , , , they are way behind the times
the car may have been restored, you may never find out.... any other state could tell you with a single phone call to the local dmv, but not penn, all they do is drivers licenses
3/26/2015 5:09:23 PM •
Chevrolet...
Answered
on Mar 26, 2015
What wrong with my 1995 silverado it has starting problems
a long list of problems, please be more specfic and I can help you
does the starter turn the engine yes or no
if no, do you hear anything, even a click
if yes
check to see that you are getting fuel
check to see if you are getting a spark
and ask your question again giving answers to these and all questions you can think I may ask
3/26/2015 5:06:20 PM •
Chevrolet...
Answered
on Mar 26, 2015
07 CADILLAC CTS 3.6L P2195, P2197 CODES
P2195 - O2 Sensor Signal Stuck Lean Bank 1 Sensor 1,
P2197 - O2 Sensor Signal Biased/Stuck Lean Bank 2 Sensor
Sounds like a O2 sensors have a problem. Auto-Zone will check these codes for you for free.
3/21/2015 3:13:09 PM •
Chevrolet...
Answered
on Mar 21, 2015
