FixYa.com
OKI Scancopier S700 Flatbed Scanner
All Products > OKI > Scanners
Problems with OKI Scancopier S700 Flatbed Scanner?
Search inside OKI Scancopier S700 Flatbed Scanner Knowledgebase
Troubleshooting and Support
Solved Problems for OKI Scancopier S700 Flatbed Scanner RSS Feed Post a New Problem
How to test a scanner for color...
How to test a scanner for color registration?
1 Solution
I unhooked by scanner ro rearrange some...
I unhooked by scanner ro rearrange some equipment and forgot how it was connected. I think it should be as follows:...
1 Solution
How to Clean a Scanner?
1 Solution
"A HI SPEED USB device plugged into a...
"A HI SPEED USB device plugged into a non HI SPEED USB hub" error message, any idea?
1 Solution
not support window xp
acer scan 620st bit suport window xp
1 Solution
Microtek artix scan 120tf
My microtek negative scans are coming out with a very strong cyan bias, and i consistently get a light cyan strip all...
1 Solution
How to add more pages while scanning with...
Is is to possible to insert / add-on more pages, while doing scanning with Umax Astra 5600 Thanks & regards
2 Solutions
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
PlatformPC
TypeFlatbed Scanner
InterfaceUSB · Parallel (IEEE 1284)
Optical Resolution600 dpi
Max. Resolution (Hardware)600 x 600 dpi
Technical Features
Form FactorDesktop
Input TypeColor
Media
Supported Media TypePlain Paper
Media Loading MethodManual Load · Autoload
Dimensions
Depth13.98 in.
Height3.58 in.
Width18.39 in.
Weight8.82 lb.
OKI Contact Information
Main support number1-800-OKI-DATA
Email supportsupport@okidata.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
