20 Most Recent
OKI C9200 Led Printer Questions & Answers
141 error
From the manual --
141 -
Drum Up/Down, Color:Magenta
When the magenta drum has been detected in an abnormal position
If you have just done some maintenance on the printer, check to see if the magenta drum is properly
seated in the slot. Then also make sure that the magenta toner cartridge is mounted properly to the
drum assembly. Both have to be properly mated in the printer to avoid the error.
How to reset fuser life error
the best soloution is to replace the unit with a brand new one as reset fuses are difficult to work with on fuser units but if you search the internet you might be able to find a reset kit from alibaba or amazon
OKI C9800 CYAN TONER SENSOR ERROR
remove drum units and clean optical sensors located at the back end of he drum slots and clean corresponding reflective plates on drum units
How to reset drums on oki c5950
Amber's solution worked on an oki c5150 as well as on her 5500.
At first, I got into other menus and did not see what she'd described. I cancelled out, then re-ran her procedure following its steps EXACTLY... At the very end, I may have seen one additional message - "EXECUTE" - which I "entered" to launch the process. Printer now works while I find instructions on how to replace "just the drum".
The OEM drum assembly is very easy to change but costs about $125. I found (on Universal Ink & Toner) a drum-only replacement for $30, but there was no instruction sheet with it. This solution has allowed me to keep working while I figure out how to install the new drum. Print quality was excellent right up until the manufacturer's internal counter shut printing down. Quality remains excellent after applying the above solution.
THANK YOU AMBER
Dave
OKI C9800 NON PAPER SENSE ERROR
remove the toner/drums and transfer belt. on the right side is the reg rollers. there is a black arm and sensor the detects the paper weight etc there. that will control the paper sense errors, make sure it moves freeley, clear of paper, dust etc.
My Okidata C330dn has a "Service Call 991:Error"
probably one of colour cartridges (usually not original from OKI) is updetting the printers logic Swap they around (even if you have to use old cartridges), find offending one and replace.
Simple.
