20 Most Recent
OKI B4200 Led Printer Questions & Answers
Printer error (0x4)
Could you provide me with the details error code.
Also the time when you get it e.g while turning on or while printing?
OKI b410d error 382
That is a paper jam code. Reopen the cover, and clear all paper jams. Close the cover, and then I would reset the machine by turning it off and on if the code continues. http://www.german-parts.de/oki_manual/paperjam/stau_b400_series.pdf
Oki b410d printer has a new toner cartridge however it is still printing inconsistently on the page?
Open the lid. Mounted under the lid you should see a horizontal bar which is actually the laser [LED]. Once your toner cart has emitted, enough loose toner has accumulated on the laser that it can no longer draw on the page correctly. Using something soft and barely dampened with water [use a soft cotton cloth, NO PAPER PRODUCTS, no dirty rags, etc] and wipe gently from L to R to remove the loose toner. Turn to a clean section of the cloth and do it once more. GENTLY! No pressure, do not scrub it, or you can damage the laser. Close the lid and print something. You should be back to good now.
