20 Most Recent Pioneer Premier DEH-P960MP CD Player Questions & Answers
Hit source button until you are in aux mode... then plug in your external music source to the front 'aux in' with 3.5mm line Jack cable. You should be able to play and control from y he external equip.
Pioneer Premier... | Answered on Oct 09, 2014
Sometimes the mechanism is misplaced, just disassemble that mechanism and turn on radio without the secondary plate and wait until the motor to get to the final position when it turns off again, reassemble.
Pioneer Premier... | Answered on Feb 04, 2014
Hello
I've the installation manual for your Pioneer DEHP960MP with me, but it is in a different language, somewhat German I thinks. All the wiring digrams are it it. But I can't upload it to you. as this Fixiya site allows me to upload 50KB only, and the document is in adobe acrobat 9 format, and have about 300KB. If you are interseted, send me your email address through Fixya. I'll send you that file as an atachment. OK.
Pioneer Premier... | Answered on Dec 06, 2010
have u connected RED YELLOW CABLES together???
Pioneer Premier... | Answered on Oct 15, 2010
i have the same problem.... mine still paying but everytime i have to take off face if i want to switch it off.... cant change songs or cd either... it happened yesterday =[
have the same problem just my back screen buttons working. dont know what to do =] will try using remote for now but cant change cd. should i try reset ?? or i should not =]
You need a ribbon cable replacement at the very least.
It's my understanding that there is a ribbon cable that needs to be replaced - it's Pioneer CNP6498 flex cable (CN871 to CN1801) at pacparts.com. Price is less than $9.00, but shipping there is crippling to say the least ($11.50 - WTF??!?!?!)
Pioneer Premier... | Answered on Aug 03, 2010
You need a ribbon cable replacement to the faceplate at the very least.
It's my understanding that there is an ribbon cable that needs to be replaced - it's Pioneer CNP6498 flex cable (CN871 to CN1801) at pacparts.com. Price is less than $9.00, but shipping there is crippling to say the least ($11.50 - WTF??!?!?!)
IF you find that the detachable faceplate also does not work, there is an additional ribbon cable that needs to be replaced. Try "DEH-P960MP" on ebay and you can find a replacement for less than $30 shipped. I received mine in 2 days and had it up and running within 20 minutes. It solved the problem.
Look the replacement cable up on ebay under "DEH-P960MP" and you can find a replacement for less than $30 shipped. I received mine in 2 days and had it up and running within 20 minutes. It solved the problem.
IF you find that the upper face (with the OEL display) also does not work, it's my understanding that there is an additional ribbon cable that needs to be replaced - it's Pioneer CNP6498 flex cable (CN871 to CN1801) at pacparts.com. Price is less than $9.00, but shipping there is crippling to say the least ($11.50 - WTF??!?!?!)
you probably have a broken flexible cable that goes from the face to the main motherboard.
Pioneer Premier... | Answered on Dec 14, 2009
you probably have a bad switch. if you have a multimeter you can check the resistance of the switches. if one is reading less than a few megaohms, that is probably the bad switch.
Pioneer Premier... | Answered on Oct 23, 2009
Most likely there is a bad capacitor in the black screen. You will have to test each capacitor to determine which one is faulty. You can purchase a capacitor tester fairly reasonable.
Pioneer Premier... | Answered on Sep 23, 2009
This is normally due to a sticky load/shuttle mechanism.
its not a simple part that can be replaced by the user.
Most times it can be cleaned - but required disassembly of the unit to do so.
Your local Car Electronics repair center (authorized by Pioneer of course) will be able to disassemble, clean and re-lubricate the shuttle for approximately $35.
For S&Gs - remove the radio and set it on your dash and try it. The angle of installation, or METHOD of improper installation can cause the body to twist, and the mechanism will bind up too. If it ejects normally without being installed - it's the installation - not the unit.
Thanks for using FixYa!!
Pioneer Premier... | Answered on Sep 22, 2009
make sure your 12volt constant is plugged in(yellow wire on stereo) and check the rest of your wiring. red(ignition power)
Pioneer Premier... | Answered on Sep 15, 2009
There are 2 thin slots on either side of the radio allowing pioneer keys to slide in and unlock.
9d01ab1.jpg you can use small allen wrenches or pieces of copper wire as well. Smash it thin with a hammer.
Thanks for using FixYa - a good rating for answering your FREE question is appreciated.
Pioneer Premier... | Answered on Jul 08, 2009
I also had this problem and the solution was to change the data bus, or if you want, you can pull out a little the data bus.
Pioneer Premier... | Answered on Jun 06, 2009
you use the FUNCTION key. Press it repeatedly until the clock option appears on the screen and then you can adjust it.
Pioneer Premier... | Answered on May 14, 2009
Pioneer Premier DEH-P960MP CD Player Logo
45 questions posted
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Car Audio & Video
Most Popular Question
faceplate keeps dropping in out
  • Car Audio & Video
