20 Most Recent Pioneer DEH-P3700MP CD Player Questions & Answers
Skipping all the technical stuff, each FM broadcast channel is 0.2 MHz wide and starts on an even number. The lowest channel for example is, 87.8MHz - 88.0MHz. Radios will tune to the center channel, ie 87.9 MHz. Any FM station in the United States is always an odd number, therefore radios in the US will never tune to an even number
Pioneer... | Answered on Mar 19, 2015
I'm having the same problem. I pressed the "function" button about 50 times and AUX never showed up.
Pioneer... | Answered on Oct 24, 2014
More than likely you have a part that is bad inside of the radio itself that is probably shorted out.
Pioneer... | Answered on Oct 31, 2011
1. hold the source button until the radio turns off.
2. then hold the audio button until a menu is displayed, which is normal the clock settings first, toggle through the menu by pressing the audio button again
3. use the arrows to change the time
Pioneer... | Answered on Oct 13, 2011
Any Local Car Audio Shop that does installs. Check with the guys in the install bays. They always have spares. Many decks from Pioneer use the same harness. Hope this helps
Pioneer... | Answered on Jul 02, 2011
You can slide in two flat thin blades or screw driver and push aside the LOCKS that hold the head unit to the frame so as to release the unit from the fittings.
Please do not use force but a simple flat AXE-SAW blade machined to fit into, must solve the issue-
The following may help you. The first is for the vehicle the second for the stereo. Good Luck.
Battery WHITE/YELLOW (+) RADIO HARNESS Accesory WHITE/RED (+) RADIO HARNESS Ground BLACK (-) RADIO HARNESS Illumination RED/BLACK (+) RADIO HARNESS Dimmer RED (-) RADIO HARNESS Power Antenna YELLOW/WHITE (+) RADIO HARNESS Amp Turn On YELLOW/WHITE (+) RADIO HARNESS LF Speaker (+) WHITE LF Speaker (-) ORANGE RF Speaker (+) YELLOW RF Speaker (-) BROWN LR Speaker (+) RED LR Speaker (-) GREEN RR Speaker (+) BLUE RR Speaker (-) BLACK Amp Location MOUNTED TO BRACKET IN RIGHT SIDE OF TRUNK Steering Cntrls YES THIS VEHICLE MAY BE EQUIPPED WITH OPTIONAL ONSTARĀ® TELEMATICS EQUIPMENT. USE AN APPROPRIATE INTEGRATION HARNESS OR INSTALLATION PROCEDURE TO ENSURE PROPER FUNCTION OF THIS EQUIPMENT. Speed Cntrl NO Radio Security YES Securityiadame_18.jpg
Pioneer... | Answered on May 17, 2011
well here it sounds like we have two problems i'm not sure if you just refering outputs from the Radio or your RCA outputs for the amp.
If your radio doesn't turn on at all definaly you need to replace the Fuse from the fusebox.
but if just your amp. first check for the main fuse and all the wiring to be hook up to it.
Pioneer... | Answered on Dec 28, 2010
if the loose speaker wire touched ground it may have blown the output ic. also make sure you have no other loose or shorted wires as this will cause the output not to work.
Pioneer... | Answered on Oct 25, 2010
Visit to the given link...
http://www.ofzenandcomputing.com/zanswers/176
Hope this has helped you... Thanks....
Pioneer... | Answered on Jul 28, 2010
Connect the wire as it was directed from the wiring harness to the head unit.
If the problem continue, there is an amp in your truck try hooking your blue and white amp.
Turn on to the blue wire for the power ant on the harness that plugs in to the truck.
That should fix the problem.
Thanks for contacting Fixya.
Pioneer... | Answered on Jul 11, 2010
Pioneer DEH-P3700MP CD Player Logo
56 questions posted
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Car Audio & Video
Most Popular Question
set clock
  • Car Audio & Video
