The first suggestion would be to check if the SD card is the correct one, and if it is correctly installed. On my Hi-Def Hard Drive Camcorder, when properly installed, the SD card looks like it's "up-side-down" - with the little metal sensors upward. It is easy to accidentally put it in - what seems to me is "right-side-up". Then I see an error message and need to flip it over. You might also check to see if the metal sensors on the SD card are all intact. Sometimes one of the little metal sensors are slightly out of line or maybe bent.
have you checked that the charger is charging the camera battery up?????
it could also be a dud camera battery,,if one cell is duff the hole battery wont charge up to its full volts so the charger works its **** off trying to charge up a dud battery till one day the charger just burns out as well?
you can make the audio louder. see about raising the volume and then when playback make sure it's not too loud. If that doesn't work then the cameras is set low in the audio. see manufacturer if they have a solution. or in the camera see if there is a volume control, maybe it's set low.
1. In setting submenu, press UP/Down Button to select Time Setting. 2. Press Menu/OK Button to go to the Time Setting menu.3. Move between date and time by using Up/Down Buttons. Adjust date and time by using Left/Right Buttons.4. Press OK Button to validate the setting. Or Press RECORD/PLAY button to leave Time Setting without any change.
The idle tire for your VCR is either dirty or has worn out and has stopped the tape reel from being able to move and turn and also the rubber parts need to be replaced or cleaned as ell.
