20 Most Recent Canon PowerShot SX130 IS Digital Camera Questions & Answers
Rechargeable batteries do wear out, and don't hold charge as well. It's about time to get some new batteries.
Canon PowerShot... | Answered on May 28, 2015
On page 69 from the manual, you find this :
25378774-asa5ihyy2wnmfnas2uabtq3a-2-2.png and here is a link to the manual. It is a PDF from Canon USA
http://gdlp01.c-wss.com/gds/5/0300003855/04/PSSX130IS_CUG_EN_03.pdf
Canon PowerShot... | Answered on Jan 23, 2015
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Canon PowerShot... | Answered on Jan 03, 2015
If your mode control dial is hard to rotate, there is chance that a sticky liquid may have sprayed or spilled, Take a q-tip with some rubbing alcohol or glass cleaner and rub around the outer edge, letting small amounts to slide under the dial. Begin turning the knob right away to work it in and loosen the stick. Make sure very little gets transferred from the q-tip, you don't want to short our the camera. It would be wise to do this with out the batteries loaded
Canon PowerShot... | Answered on Nov 28, 2014
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Canon PowerShot... | Answered on Nov 22, 2014
Try NOT connecting your camera to your computer.
Canon PowerShot... | Answered on Nov 20, 2014
Canon PowerShot... | Answered on Nov 19, 2014
You can download the PDF manual from the manufacturer's web site at
http://www.usa.canon.com/cusa/consumer/products/cameras/digital_cameras/powershot_sx130_is#BrochuresAndManuals
Canon PowerShot... | Answered on Oct 13, 2014
This is a fixed lens camera, you cannot change lenses. If there is some problem with the camera's lens the best advice I can give you is to take it to a camera shop for repair.
Canon PowerShot... | Answered on Aug 28, 2014
Canon will send you a new one for free or minimal cost. There is a pin that acts as a hinge. push it out from the side with a paperclip or very small screwdiver or punch. reinstall the new door in reverse careful of the spring. Some cameras, there's a screw holding the door on, in this case the new door will include the hinge.
Canon PowerShot... | Answered on Aug 22, 2014
I had a similar problem my camera kept telling me to raise the flash even when it was raised. I opened the back of the camera taking out the little screws on the back only. To the right right below the flas is a switch that registers when the flash is raised. Something had broken off in mine because nothing would push the switch. I wedged it down with a foam nose pad for glasses (came in the kit i bought for the screwdriver). Now flash registers all the time so I have to manually change the setting if I don not want flash but it is working now.
Canon PowerShot... | Answered on Jul 06, 2014
You receive a flash warning because the image does not have enough light for the aperture and shutter speed combination either you have set or the camera has set. There are several solutions. I can't seem to find whether that camera has a manual exposure mode or only auto modes. If only auto modes, refer to number 1 and the last two bullets.
Solutions.
1. Turn on your flash. If you do not want to use your flash....
2. If you have the ability to adjust your exposure settings
  • Open your aperture to it's widest ability. That would be a small number like 2.8 or 3.5
  • Reduce your shutter speed to about .125 Anything slower than that may introduce blur into the image depending on how steady your hands are.
  • Increase your ISO upwards toward 1600. Be cautious though. The higher the ISO, the more grain or noise is introduced into the image.
  • Do not use optical zoom (16x). Use only digital zoom (4x). You lose too much light at super zoom levels and the pic gets too shaky anyway.
Canon PowerShot... | Answered on Jul 02, 2014
Try visiting ifixit, On ifixit.com. This site has lots of guides, video tutorials and other things that can help you when you want to repair your equipment, for free.
You even can buy repair tools and spare parts. (these will cost you)
Canon PowerShot... | Answered on Jun 29, 2014
Be carefull, never use force. Check if you don't try to put in the card the wrong way around. Then check if nothing is damaged inside the memory slot. You need a bright light and perhaps a magnifying glass, because everything is very small. Compare the memory slot with a memory slot from another camera. Watch how the little knobs on the side look. I don't mean the contacts. When the contacts are bent, there is a possibility someone once pressed a memory card in the wrong way around and damaged the contacts and knob to secure the card.
Canon PowerShot... | Answered on Jun 03, 2014
Canon PowerShot SX130 IS Digital Camera Logo
190 questions posted
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
PowerShot Canon
  • PowerShot Canon
Most Popular Question
replace door battery powereshot xs 130
  • Cameras
