20 Most Recent
Samsung B2230 LCD Monitor Questions & Answers
Nothing happens when the power
make sure the power cable is inserted properly. try to unplug it and put it back again. if it doesn't work, try with a different cable, use your friend's cable with your monitor to check it out. if it works, then the problem is with the cable, if it still doesn't work, reply to this message please.
Resolution issues with samsung b2230
did you installed your graphics driver if not install it first and you can change your resolution may be your system don't have that capacity you have to buy a graphics card that will fit to your system config and instal drivers it will work. hope that it will help you thanks
When I was attaching the screen to a VESA arm, one
As it appears it seems that the back of the unit is held together by clamps. I wouldn't advise you to go ahead with the dis-assembly because you risk breaking the clamps. But if you must do it proceed with caution. Start prying open from the bottom screws toward the top of the unit. Use a plastic wedge to help the prying. It really comes down to finesse and experience. If you don't feel confident doing it don't do it as you might break it irreparable.
The mount should be usable even mounted in 3 points.On the other hand the loose nut could cause some damage short circuiting the board. \Good luckVlad
I have no sound on my new monitor
Hello John Kath624,
The Samsung B2230 LCD Monitor does not seem to have any speakers.
At Samsungs website the specifications state that there are no speakers:
linkSincerly,
Tim Jansen
My New Samsung B2230 LCD
Turn down the brightness of your monitor. There are touch sensitive buttons beneath the Samsung logo that will adjust things accordingly.
Maquina de lavar Samsung wf90f5e5u4w
ENGLISH ONLY please.
Samsung washing machine wf90f5e5u4w
Hello good afternoon, I want to ask for help, I have a faulty module and I wanted to ask if you have the electronic diagram for the Samsung DC92-01240C washing machine, the machine model wf90f5e5u4w, I would really appreciate it if you could, thank you. greetings Antonio Paulo
Steam Wash, Washers Support ' Samsung Care US
Samsung
https://www.samsung.com > washers > front-load > ste...
Get the latest drivers, manuals, firmware, and software. Learn more. Request repair service. Arrange for a service visit at home, schedule a walk- ...
https://www.google.com/search?q=Samsung+DC92-01240C+service+manual
12/4/2023 10:19:25 PM •
Samsung...
Answered
on Dec 04, 2023
