There is a trouble shooting document behind the kick panel at the bottom of the machine. Follow the steps to determine which component is at fault. However corrosion may be causing this:
My whirlpool dishwasher gold GU2475XTVQ0 had rapid blinking lights that started with the "4 Hour Delay" LED and changed to others when other buttons were pressed. The machine would not run. I followed the instructions located behind the kick panel and verified the keypad was the issue and not the control circuit by elimination.
The big surprise for me was that when I used a straight pin to resistance check all of the buttons, they checked out OK. I reconnected the 14 pin connector (P1) to the control and found that the buttons/LEDs were behaving correctly! I believe that pushing the straight pin into the 14 pin connector removed any corrosion in the 10 year old device and permitted the keypad to communicate with the control again.
I reassembled the dishwasher door and it ran with no problems. I was ready to replace the keypad for $150, but didn't have to!
I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
using tape measure measure your item of here is dimensions. you can buy a DW that is 24 inches wide, very easy to do. It is a standard size DW
Width23.875"Depth24.5"Height33.875"
Try a mainboard Reset. Pull the mains plug before bed tonight. Tomorrow, press and hold the on button for 30 seconds, then let go and plug it back in.
My plan was to see if I could find you a service manual, but strangely, the only reference to that model number is your post here! My guess is the D6 is 'D for Dishwasher' and 'Series 6' or 6 models in that current series.
If the machine has been laid up or little used, check all the connection on the control board. Clean pins and plugs with electrical switch cleaner
https://www.google.com/search?q=DU940QWD6
Most likely a bad heating element..
https://www.youtube.com/watch?v=am-fhX92rbw
You can call Repairclinic 800# too, and talk with a tech, before throwing parts at it. 800-269-2609.
Best to you.
Miniplayer (i)
We'll also want to shut off the inlet watersupply and disconnect that as well.
0:30/8:42
Please refer to youtube " Whirlpool Dishwasher Repair - How to Replace the Pump (Whirlpool # W11032770) "
The loud popping noise that you're hearing when you open and shut the door of your Whirlpool dishwasher (model # WDT780SAEM1) is most likely caused by the door gasket. The door gasket is the rubber seal that runs around the door, creating a tight seal when the door is closed.
Here are a few things you can try to fix the issue:
Check the gasket for damage: Inspect the door gasket for any tears, cracks, or other damage. If you find any damage, you will need to replace the gasket.
Clean the gasket: Over time, debris and food particles can accumulate on the gasket, causing it to become stiff and not seal properly. Clean the gasket with a mild detergent and warm water, and then dry it thoroughly.
Check the door alignment: Make sure that the door is properly aligned and not hitting the gasket when you open and shut it. If the door is not aligned properly, you will need to adjust it.
Lubricate the hinge: If the door gasket is in good condition and properly aligned, the problem may be with the hinge. Try lubricating the hinge with a silicone-based lubricant, as this can help to reduce friction and noise.
Contact Whirlpool: If you have tried all of the above steps and are still unable to fix the issue, contact Whirlpool customer service for further assistance. They will be able to provide you with additional troubleshooting steps or advice, or they may need to send a technician to repair or replace the dishwasher.
It's important to note that if the popping noise you're hearing is accompanied by other symptoms, such as leaks, then it may be related to a different problem, and you should contact Whirlpool customer service or a professional service technician for further diagnosis and repair.
Es posible que la luz Soak & Clean del lavavajillas Whirlpool Gold Quiet Partner III no se encienda si el lavavajillas no est? recibiendo energ?a o si el lavavajillas no est? en el ciclo correcto. Se recomienda verificar la fuente de alimentaci?n y asegurarse de que el lavavajillas est? enchufado y reciba energ?a. Si la alimentaci?n est? conectada y el lavavajillas est? en el ciclo correcto, entonces es posible que haya un problema con los circuitos o el cableado del lavavajillas. Se recomienda ponerse en contacto con un centro de servicio autorizado de Whirlpool para obtener m?s ayuda.
