Troubleshooting & Support
Hot Topics:
- leaking water
- wa
- wk2910
- main control...
- LE
- remove icemaker
- a42 smeg door...
- fix poor images...
- water drain pan
- Refrigerator
- water
- ice
- water ice maker
- 2006 maxima sl...
- hxd5 case open
- sidebyside...
- sub zero 700...
- seat ibiza 2003...
- freezer
- ice maker
- drain pan ice...
- dresser drawer...
- eaton avr 1250...
- 05 durango air...
- water leak
- air
- french
- remove ice...
- door sealing
- fix stopcable...
- View All »
Problems & Solutions
How can I calibrate the water intake to my...
Yes just turn the t handle down at the water source
water leaking into bottom of refrigerator section
Make sure you dry everything in the freezer when you have the door open and remove ice. It won't be a leak it will simply be the warm...
ge side by side ref.
no,its more than likely the defrost heater located just under the coil thats freezing up,check this heater for continuity,if its o.k. then...
where is the auto defrost timer, and can i by pass...
no you cant bypass the defrost timer/a.d.c. depending on the model its either controlled by a timer or off the main board in the rear of the...
I need to find out where the defrost heater and...
remove the lower inside back panel inside the freezer and the heater and thermostat are on the coil behind the panel, its straight forward...
GE profile fridge mod# PDS20SCRRSS is not cooling...
GE refridgerators have what they call a main dome control board. This is located on the back of the machine, usually closer to one side or...
My side by side GE Profile refrigerator has uneven...
yes you should be able to adjust the door at the base of the door at the hinge with a 3/8" open end wrench
will not dispense ice
commonly what you will find on that model is the main control board on the back of the unit is the source of your issue, it begins like a...
GE Profile Model PTC22MBMBRCC Counter Depth...
you have a defrost issue which need to be dealt with. the fans is hitting the ice that has formed after 5 to 10 days of not going through a...
We have a small GE refrigerator, 769T Serial...
have you punctured the evaporator? as this can happen trying to brake the ice off as it is very soft alli, can you hear the motor running?...
I have a GE Profile Performace Refrigerator and...
Check the water solonoid on the lower right side facing the rear of the unit. the water line connects to it. sounds like it might be...
GSS25UFPBBB refrigerator not cooling properly
Defrost it again remove the back freezer wall panel. At the bottom of the coils is the defrost heater. Replace it and...
GE bottom freezer, model PDS18SBMARBS; How do you...
Here is a diagram of your unit. The timer is number 47 on the diagram. This should help you. The screws may also be the Torx type or metric.
how do I remove ge GBS20KBPACC handle for reverse...
You just grab the handle with both hands and pull/lift up like your trying to lift the fridge wirh the handle. It should disengage and then...
how to repair broken water line at water pump
There are repair kits available, Contact your local GE parts retailer and give them your model info.
See all GE Profile PFSS6PKX Bottom Freezer French Door Solutions
Unsolved Problems
control panel flashing 88
Experienced an area power outage today. When returned home, fridge control panel flashing numerals 88 in both...
how to calibrate water intake for ice maker
Ice cubes keep freezing together and jaming the icemaker
Deli drawer lid hinge snapped
small pin type/pivot hinge on left side snapped off
ge profile pfs f6pkx, 3
ge profile pfs f6pkx, 3 yrs old, ice maker is making a clicking noise and not producing ice. took it apart and did see...
I have a GE Profile
I have a GE Profile refigerator model number PFSS6PLX. My ice maker will not make ice. I replaced the filter. We have...
fridge is not keeping cool,
fridge is not keeping cool, it gets to the set temperature but then it warms up, I unpluged it to reset and now the...
See all GE Profile PFSS6PKX Bottom Freezer French Door Problems
Manuals & Guides
TopDo you have a manual for GE Profile PFSS6PKX Bottom Freezer French Door Refrigerator? - Upload it to FixYa!
Upload a manual for GE Profile PFSS6PKX Bottom Freezer French Door Refrigerator
Specifications
TopKey Features
Full Product Name:GE Profile PFSS6PKX Bottom Freezer French Door Refrigerator
Installation:Built-in
Refrigerator Type:Refrigerator
What's your problem?
Fix-O-Meter
862
862 people have viewed this product
- 32 people asked about this product.
- 2 people found solutions for this product.
- 0 people have added this product. Be the first!
General Safety...
Pins on the...
How to fix your...
