20 Most Recent
Frigidaire Clothes Dryer Thermostat 5308015398 Questions & Answers
Where is the air intake on an electric cloth dryer
This link is to a video about cleaning a blower box lint trap housing of a Whirlpool , Frigidaire or Kenmore dryer..
There is a good view of the back of this dryer. Other than the controls and trim all of these models and makes are nearly identical.
As viewed from the back the air intake is at the lower right. The air enters the bottom of the heater flows through the heater coils into the dryer drum out of the dryer drum into the lint filter blower box into the blower and is expelled out into the dryer vent pipe.
There are other makes that may be different. On some LG dryers the blower is located at the front bottom left of the machine.
There are lots of help videos on youtube.
Whirlpool Kenmore Dryer Repair Remove and Install the Blower Box Lint...
Frigidaire front load dryer, displays E72 call service, what does this mean?
Hi Don, this is AP!
I understand you are receiving an error code of E72 on your Frigidaire dryer. Without knowing the model number specifically I can tell you the general explanation for an E72 code is an outlet control thermistor short circuit. The recommended solution is to check the resistance of the outlet control thermistor, and check wiring for a short circuit across the thermistor connections. Resistance should be between 4.9K ohms and 6.2K ohms at room temperature (68-77F or 20-25C). You may possibly need to replace the outlet control thermistor and/or wiring and retest.
However, this is not a typical DIY project. I would recommend reaching out to an experienced appliance technician just to ensure no troubleshooting step has been missed. Parts are often costly and if the problem is precisely diagnosed, it can save you a lot of time and funds.
Best of luck,
Dryer running but will not
Almost always this means the heating Element has went out. They are not very expensive and are easy to replace.
Thumbs Up if helpful!!!
My Frigidaire Affinity washer makes a loud buzzing sound when you push the start button and will not start, what can I do
Good Morning Anonymous, this is Z. I am happy to assist you!
I understand that your door indicates it is open and your dryer will not operate. Let's attempt resetting your dryer by either unplugging it or flipping the household circuit breaker off. It is good to wait approximately ten minutes and turn on your dryer. Select a normal cycle and verify if your dryer will start. If your dryer will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. At this point, it would be advisable to contact an experienced appliance repair tech to assist further.
What's stopping my dryer from running continuously
Please power cycle your dryer and attempt to run it again. If this fails, please ensure that your clothes are evenly distributed so that they weight of the clothes doesn't cause the dryer to be shutdown. Just to double check, please ensure that you've cleaned the lint track of your dryer. Lastly, you can use an power outlet extender to help switch the power outlet that you're using to run your dryer as there might be something wrong with your current one.
Thank you.
My Frigidaire dryer won't run longer than 5 secs what's wrong how can I fix
There could be several issues that could cause your Frigidaire dryer to stop running after just a few seconds. Here are a few potential problems to consider:
- Thermal fuse: The thermal fuse is a safety device that shuts off the dryer if it overheats. If the fuse has blown, the dryer will not run.
- Clogged dryer vent: If the dryer vent is clogged, it can cause the dryer to overheat, which could trip the thermal fuse.
- Faulty cycling thermostat: The cycling thermostat regulates the dryer's temperature. If it's faulty, the dryer may not run for more than a few seconds.
- Faulty start switch: If the start switch is faulty, it could prevent the dryer from running.
- Faulty door switch: The door switch prevents the dryer from running when the door is open. If the switch is faulty, the dryer may not run.
To fix the problem, you'll need to diagnose which of these issues is causing the problem and then replace the faulty part. I recommend having a mechanic diagnose and fix the problem for you.
WHAT IS E11 ERROR CODE IN MICROWAVE FRIGIDAIRE
The E11 error code indicates a problem with the gas sensor DE32-60011A and or the wire harness DE39-40678D. Unfortunately the manufacturer has discontinued the sensor. You may want to try contacting local parts dealers, one of them might still have it in stock. Enter your part number in a search engine, a smaller company might have it or try eBay, Amazon or similar sites . Search by using the manufacturers part number. Try a used appliance store, sometimes they have the same model or a usable part for your machine.
