20 Most Recent TaoTao Manufacturer Inc Kids Skateboard & Protect Gear Combo / Aloha Questions & Answers
Hello David,
There isn't much you can actually do for it,, just keep the air filter clean and treated, keep a fresh spark plug in it.. its about the best it will be like it is..
TaoTao... | Answered on Jun 19, 2017
Hi, Steve, I would love to help you with your engine or chassis noise but I just loaned my brand new pair of listening ears to your local dealer's chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. If you are a little short on "DRACHMA" and a Dealership is not on your list of fun places to visit then perhaps the list below will help soothe your worried mind so you can make an informed decision.
1. Bearings---SCREECH---WHINE
2. Belts---CHIRP
3. Brake Rotors---BUZZ
4. Cam Chains---CLICKIT
5. Clutches---CHATTER
6. Cylinders---PING
7. Fairing Panels---WHISTLE
8. Fenders---SCRAPE
9. Fronk Forks---Plunk
10. Fuel pumps---WHIRR
11. Gears---WHINE
12. Head Gasket---HISS
13. Hydraulic Lifters---TAP
14. Instrument Clusters---BUZZING
15. Kick Starter---GRINDS
16. Pistons---SLAP
17. Power Valves---CLINK & RATTLE
18. Radiators---GURGLE
19. Rear Chains---RATTLE
20. Rear Shocks---SQUEAK
21. Relays---CLICK&BUZZ
22. Shaft Drives---WHIRR
23. Shifting Trans---CLUNK
24. Solid Lifters---TICK
25. Speedometers---bzzz
26. Starters---CLICK
27. Starter Clutch---GRIND & WHIRR
28. Rods Go---KNOCK-KNOCK---who's there, it's me "*****"
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Scooter Troubleshooting Scooter won start All about Scooters Tao Tao ATV wont start Fix it here
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
https://www.taotaopartsdirect.com/collections/lancer-150
TAOTAO QUANTUM 150 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
TaoTao... | Answered on Apr 28, 2018
Hi, Bob for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Amazon com Poweka New 39mm Air Filter Gy6 Moped Scooter Atv Dirt Bike...
TaoTao 50cc Scooter DIY Air Filter Replacement PT 1
TaoTao Scooters Mopeds Parts
TaoTao ATM50 A1 Owner Manual
TaoTao... | Answered on Mar 01, 2018
Hi, Brad for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your TaoTao, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Taotao ATM150 Evo scooter replacement of fuel and vacuum lines
Taotao ATM150 Evo scooter fuel tank vent line gas leak fix
http://absolutelyscooterparts.net/pdf/CGen_GY6_50cc_Service_Manual.pdf
Eagle Atv Parts
TaoTao... | Answered on Dec 01, 2016
cvc
TaoTao... | Answered on Oct 27, 2016
there is a wiring plug under the seat it may have a come out or the wire has corroded., also check the earth it is around the same area.
TaoTao... | Answered on Oct 21, 2013
If my memory serves me correctly the dash needs removed (hard work) and work then easy
Motorsports | Answered on Feb 04, 2018
great mercadolibre com mx http://www.soccerphysicsonline.com/
Motorsports | Answered on Jan 15, 2018
you need to post what engine you need firing order for
Motorsports | Answered on Nov 30, 2017
Check for a bad fuse..not sure where it is but look in the owners manual or inside cover of the fuse panels for the wiring diagram
Motorsports | Answered on Sep 14, 2017
The alarm you hear may be the overheating alarm... but, if it is, it won't run too long with it on before the engine locks up...Is there evidence of water coming from the witness hole in the back of the motor? Good.. otherwise,, you may be hearing the low oil alarm..or the oil pressure alarm...My bass boat oil system alarm goes off every time I crank the engine..but it uses oil and runs great...(been doing it for years - I am too lazy to clean the sensor in the oil tank)
The RPM and faster alarm is something that puzzles me?
Motorsports | Answered on Jun 14, 2017
in manal that you have recived in the car should be explained what every fuse is doing.
Motorsports | Answered on May 31, 2017
Go to a smaller exhaust or a longer exhaust (not practical. Engines need some back pressure. That is why headers on dragsters are all of equal length.
Motorsports | Answered on May 30, 2017
Believe it or not, Home Depot, whom I despise. A low/bad chip should not cause slow engine crank, if that is what you meant. Show crank is low amperage. Weak starting battery or electrical connections at either the battery or the engine.
ARE YOU SURE IT IS A FUEL DELIVERY PROBLEM? SPARK & FUEL ARE THE 2 THINGS THAT CAUSE A VEHICLE TO START AND RUN. IF IT USES "COILPACK(S) HAVE THEM /IT TESTED...LIKE AT AUTO ZONE...OTHER IGNITION SYSTEMS, MAKE SURE YOU ARE GETTING A FAT STRONG SPARK OUT OF COIL!....WHEN YOU TURN THE IGNITION SWITCH TO RUN POSITION (DON'T CRANK IT OVER)....WITH THE DRIVERS DOOR OPEN..YOU SHOULD HEAR A WHIRRING SOUND MOMENTARILY FROM THE REAR OF THE VEHICLE. THIS IS THE FUEL PUMP RUNNING. IF YOU DONT HEAR A FAINT HUMMING...THE FUEL PUMP
1. IS DEFECTIVE
2. IS NOT GETTING POWER
3. YOU HAVE A RELAY OR WIRING ISSUE (UNDER HOOD MAXI FUSE AS WELL). IF NOISE IS HEARD..GO TO SPARK DIAGNOSIS JEFF GEYER (517) 489-1566 OWNER AUTOWORX
Motorsports | Answered on May 18, 2017
unencrypt the question! lol?
Motorsports | Answered on Mar 26, 2017
First of all let me tell you that it is a myth that you can not go back and forth between conventional oil and synthetic or in your case synthetic blend. They all mix very well together but why on earth would you not use a full synthetic in every thing? It will keep your motor so much cleaner, and last way longer, new or 150.000 miles used, does not matter. They refine the synthetic oils way way longer to get the impurities out. Other big thing [ OILTEMPERATURE AND WEAR COLD START UPS ] Exceeds and blows conventional out of the water. plus a real full synthetic you can run a lot longer just spin a new good grade filter on or change it. Me my self Ill run Walmart full synthetic in my grand prix and ROYAL PURPLE in my 2013 mustang. I think there all full synthetics are good compared to the old dirty sludge and if all the new manufactures are recommending it now its good. Do you have any motor rebuilders or trucking builders close to you? Just go look at the oil pans to compare the too . I guarantee you will be sold that day and never run conventional again.... PERIOD.
Motorsports | Answered on Feb 09, 2017
Call around, the one that is busy is the one you want.
Motorsports | Answered on Feb 02, 2017
TaoTao Manufacturer Inc Kids Skateboard & Protect Gear Combo / Aloha Logo
1 questions posted
Top TaoTao Manufacturer Inc Motorsports Experts
Steve P
Steve P
 Russ Hill
Russ Hill
chuck ringwood
chuck ringwood
Are you a TaoTao Manufacturer Inc Motorsport Expert? Answer questions, earn points and help others
View Most Popular
  • TaoTao Manufacturer Inc Motorsports
Most Popular Question
show me fix 2015 taotao will run better
  • Motorsports
