Dear sirs I can not find a optical replacment for my DV868AVI 220v
Is any chance to find...
(More)
Is any chance to find anywhere?
Sincerely
Diego
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
CD-RW · CD-R · CD (Audio) · DVD Audio · VCD · DVD-RW · SVCD · DVD Video · DVD-R · SACD
Playable File Formats
MP3
Video
Picture Control
Brightness · Sharpness · Saturation · Black Level · Hue · White Balance
Video Output System
NTSC · PAL
Video DAC
14 bit / 216 MHz
Video Noise Reduction
Block Noise Reduction · Mosquito Noise Reduction
Audio
Surround Sound
Built-In Dolby Digital Decoder · Built-In DTS Decoder
Audio DAC
24 bit / 192 kHz
Dynamic Range
109 dB (DVD)
Dialog Enhancer
Yes
Audio S/N Ratio
118 dB
Connections
Outputs
Composite x 2, S-Video x 2, Component x 1, RGB (via SCART), iLINK DV Output, HDMI x 1, Analog Audio x 1, Analog Surround x 1, Digital Audio Coaxial x 1, Digital Audio Optical x 1
