20 Most Recent Pioneer DVL-V888 DVD Player Questions & Answers
replace d105 it shorted
Pioneer DVL-V888... | Answered on Jan 02, 2015
happen to all disc?
if so, check the 'home' sensor for the tray. need to open up and take a look.
Pioneer DVL-V888... | Answered on Jun 14, 2014
go please to www.fitness.manualsonline.com or www.retrevo.com or www.manualsfactory.com
God bless you
Pioneer DVL-V888... | Answered on Jul 22, 2012
if it does not power up, then it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Pioneer DVL-V888... | Answered on Mar 12, 2011
Required remote control for Pioneer DVL-V888 is available in Remotes.com
Please click on above link to view remote image, price info and online order.
Hope this will help.
Thanks.
Pioneer DVL-V888... | Answered on Mar 07, 2011
Unfortunately it seems that the Flash ROM memory that contains the player's firmware is going bad (has a bad integrated circuit chip). The firmware contents most often have a calculated checksum stored with the code/data in ROM. The player at startup compares the read checksum with what it calculates from reading all the ROM contents. When the read versus calculated sums do not match, then it knows, and is alerting you, that some ROM location is going bad and not to trust the player to operate right.
The only thing to do is to have Pioneer fix the player. Sorry!
You could try to disconnect the power supply for few minutes, say 30 minutes and see,if that rests the problem unless repair is the only option.The repair cost i guess, would be anywhere between $100 - $150 plus shipping charges.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Pioneer DVL-V888... | Answered on Dec 15, 2010
I believe there is something prevent the disc tray from ejecting. This is also happening from the internal part of the player.
Get a screw driver that can fit into the screws of the of the player, unscrew the player's cover so that you can gain access into the internal part of the player. Press the eject button and check if you would see anything restraining disc tray from pulling out.
Also, assist the disc try by pulling it out or pushing it from the inside while you push the eject button.
You can also remove the disc manually/directly in the process if you want to.
Good luck.
Pioneer DVL-V888... | Answered on Nov 07, 2010
Likely that it's just a fuse, take the cover off and replace the mains fuse located close to where the power lead is, if it blows again, you will have a power supply fault. Phil
Pioneer DVL-V888... | Answered on Nov 17, 2009
replaced d105 it shorted
There isn't a way to open it by hand without removing the cover.
As for fixing the tray, there might be a few reasons why its not working. When you press one of the eject buttons, do you hear the usual whirring of motors? If you do and the tray still does not open, then the problem may be a broken rubber belt near the front.
If you don't hear the whirring of motors, then try playing the disk. If the disk does not play either, then the disk loading mechanism is out of sync and may require manually resetting it. This is accomplished by carefully pulling the spring loaded carriage upwards or downwards until it responds to the play button. Be very careful not to touch any of the exposed electrical components and capacitors, electrical shock may occur.
Pioneer DVL-V888... | Answered on Jun 03, 2009
Hello There
Most Likely that it's just a fuse, take the cover off and replace the mains fuse located close to where the power lead is, if it blows again, you will have a power supply fault so a new power supply circuit board is need. If it just stopped working all of the sudden then it will be the fuse. ( Please ensure the unit is not plugged in when opening the unit)
Hope this helps. Please don't forget to rate me.
Many Thanks
Pioneer DVL-V888... | Answered on May 20, 2009
You need to remove the cover and expose the area where the motor sits close to the front, you will find a broken belt, replace that, if you can't get to the screw to remove the assembly, use your fingers or screwdriver to turn the cog so that the drawer is manually opened. make sure power cable is unplugged first.
Pioneer DVL-V888... | Answered on May 19, 2009
Hi
Some driver have a small hole on the front where you can use a paper clip or similiar to eject the drive.
if you don't have this small hole on the tray. Unplug and replug the set and try again. also try holding down the eject button. If nothing is happening. The last solution is to take the drive apart to eject it.
A small belt could be loose, do you hear a motor sound when you press eject?
if you have warranty it maybe void if you take it apart.
Pioneer DVL-V888... | Answered on Jan 25, 2009
DVD players are a dime a dozen, go get a new one....
Next time try to get a name brand such as a sony etc...
Pioneer DVL-V888... | Answered on Aug 29, 2008
you will have to take apart and see if you can push the disk into position other wise have to take apart tray system and remove disk.
Pioneer DVL-V888... | Answered on Dec 03, 2007
  1. Have you tried cold starting it; disconnect it completely from the mains for ~10 mins, then reconnect and try again.
  2. It is probably a problem with the EPROM or the CPU. You could try resetting the software by holding in the STOP button while turning on the power to the unit. If that doesn't work it sounds like the EPROM is corrupt or the CPU is bad.
Pioneer DVL-V888... | Answered on Nov 12, 2007
is there a tiny pinhole to push in a paper clip to eject the tray?
Pioneer DVL-V888... | Answered on Jul 11, 2007
Pioneer DVL-V888 DVD Player Logo
Popular Tags
27 questions posted
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Televison & Video
Most Popular Question
get
  • Televison & Video
