i cant see a thing my lcd samsung i think it's not compatible. well i was looking for menu's and...
(More)
i cant see a thing my lcd samsung i think it's not compatible. well i was looking for menu's and trying... and i witch it to progresive so now i cant see a thing? can someone help?
halli99 again...forgot to say ,would any other remote b ok to use on the pioneer dv-373,so i would...
(More)
halli99 again...forgot to say ,would any other remote b ok to use on the pioneer dv-373,so i would hav better choice..thanku
I have recorded a dual layer DVD and my DV-373 plays it fine for the first hour and then stops dead....
(More)
I have recorded a dual layer DVD and my DV-373 plays it fine for the first hour and then stops dead. Is this because this model does not play dual layer disks? Or just an error with the recording (the disk did verify just fine during the recording process)
given universal DVD player remote but i cannot make it function because i dont't have the necessary...
(More)
given universal DVD player remote but i cannot make it function because i dont't have the necessary codes. Can you help me?
I was playing a DVD and tried to adjust the picture as it was only showing in the centre strip of...
(More)
I was playing a DVD and tried to adjust the picture as it was only showing in the centre strip of the screen. Now when I turn on my dvd the Pioneer screensaver doesn't show and no visual play but I have audio. No connections were touched and GUI is on the DVD player screen. I used the remote to adjust the picture(won't do that again)but no matter what I do the remote will not work when I try to select the menu Please any help will be appreciated. Have tried to power everything off but didn't help Owen
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
