20 Most Recent EliteGroup P6IWP-Fe Motherboard Questions & Answers
go to this webpage
http://www.ecs.com.tw/ECSWebSite/Product/ProductArchive.aspx?CategoryID=1&MenuID=24&LanID=0
Identify your m/b - there is a ver 1 and a version 2 of the P6IWP-Fe. near the bottom of the linked page, which seem to blank, there some tabs; click the one labeled CPU. The list of supported CPUs will appear below (scroll down to see them) with the earliest BIOS version to support the CPU in the RH column.
EliteGroup... | Answered on May 24, 2016
maybe you need a new video chip
EliteGroup... | Answered on Jun 25, 2012
Download DRIVER GENIUS:
Install then scan for missing & outdated drivers.
It will automatically download your drivers from their server.
After downloading install your drivers.
It's easy and safe...
If you find that this is information was helpfulto you, please rate me and leave a comment as this will encourage me to do morefree work for you and others. And please let me know if there's anything else Icould help you with. Without any inputswe cannot proceed assisting... Thank you for using FIXYA! Best regards,
Junior
EliteGroup... | Answered on Sep 14, 2011
i dont know about fixing the capacitors
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=280406610810&ssPageName=STRK:MEWNX:IT$1+$2.46 postage worldwide
You might get these on Ebay im not sure which country you are in this might guide you to one
you could get this on Ebay if you dont have an account you will need to create one
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card phone numbers home/mobile ,email adress and a postal adress
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps
EliteGroup... | Answered on Aug 31, 2011
Use this site to locate the drivers you need for your motherboard and devices:
http://www.ecs.com.tw/ECSWebSite/Downloads/Downloads_list.aspx?MenuID=61&LanID=9
I hope this helps! If this did help you, please give a thumbs up!
EliteGroup... | Answered on Jun 28, 2011
Intel PentiumIII, 512mb RAM max. an old board!
EliteGroup... | Answered on Jan 11, 2011
check the capacitor in to your board and check if there is not capacitor globe.
EliteGroup... | Answered on Nov 03, 2010
If you have your computer Recovery disk, place the disk in the drive and restart the computer. It sounds like your OS is corrupted and needs to be reloaded.
EliteGroup... | Answered on Apr 06, 2010
Try to change RAM first..if not worked then the processor ...
EliteGroup... | Answered on Apr 21, 2009
If you are using a USB keybord then you will have to change the settings in your bios setup so as to enable USB support, thus you will be able to use you usb keyboard and usb mouse, but you will obviously need a ps/2 keyboard in order to access the bios setup and make the necessary changes. On the other hand if you are already using a ps/2 keyboard the problem could be the keboard, so try another one if that does not work then you keyboard slot could be damaged (try a usb keyboard - with any luck the usb interface would already have been enabled but you can also enable it within your operating system just using your mouse. Also check with your ps/2 keyboard that you are pluging is in the correct slot (purple- keyboard, green- mouse)
EliteGroup... | Answered on Oct 17, 2008
Howzit
Okay, the problem here is that there is no guarantees when hottswaping motherboards. First It helps if the mboard your swap to is of the same manufacturer thus this eliminates some driver identification problems with XP. Second the socket set (as you said PGA370) must be the same. Then VGA setup must be the similar as in, if its onboard on the first mboard it must be onboard for the second mboard. Otherwise you should be fine. Another option that you did not mention is creating a second partition on the harddrive and installing XP with any other motherboard onto that pertition you created. That way you can just simply copy you information across when you are running with your new mboard (this may be your best option) . Let me know how you go. Thanks
Regards
EliteGroup... | Answered on Jan 31, 2008
There's two versions of your motherboard listed version 1.0a and version 2.0 i've listed the links for updated software, drivers, bios and manuals for both, though version 1.0a doesn't have a listing for a downloadable manual it has all the other bits and pieces, i've also listed the link to help you identify which version your mainboard is:
software,drivers,bios etc, ver 1.0a:
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=95&DetailName=New&DetailDesc=&CategoryID=1&MenuID=6&LanID=0
software,drivers,bios, manuals ver 2.0:
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=210&DetailName=New&DetailDesc=&CategoryID=1&MenuID=6&LanID=0
version ID help:
http://www.ecs.com.tw/extra/productinfo/MB.htm#ver_mb
Hope this helps you out
EliteGroup... | Answered on Nov 03, 2007
The ECS website.
EliteGroup... | Answered on Oct 19, 2018
EliteGroup P6IWP-Fe Motherboard Logo
Popular Tags
20 questions posted
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Matson Kurian
Matson Kurian
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • EliteGroup Computers & Internet
Most Popular Question
no video from motherboard
  • Computers & Internet
